New lights are in :)
Looking and seeing great, ty Matt
Just one question though, what do we use to supply power to the halos? I was going to hook them up to a power source, but I don't want to blow them.
Will post pics later
RE: New lights are in :)
ORIGINAL: Smooth_J
There are three wires located on the turn signal harness. These wires are: black, gray, and green/white striped. The black wire is the ground. The gray wire should be treated as the power wire. The green/white-striped wire controls the intermittent signal for the turn signals. Therefore, take the black wire coming off of the halos and tap them into the black wire coming off the turn signal harness. Then, take the red or white wire coming off of the headlamps and tap them into the gray wire coming off of the turn signal harness. You must repeat this step on both sides. This will now allow the halos to turn on when you have the corner lights on.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
