Go Back   MustangForums.com > Vendors & Sponsors > StangSuspension.com
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-20-2007, 12:36 AM   #1
eagle94
Default driveshaft hitting e-brake bracket
drive shaft hits bracket with 2 people and full tank, pushing down on tail of car it goes down a ways but shocks rebound right up and stay no bouncing. just bought car but doesn't look lowered. do lowered cars have this problem. do i need new shocks.
eagle94 is offline   Reply With Quote
Old 06-20-2007, 09:00 AM   #2
eagle94
Default RE: driveshaft hitting e-brake bracket
car is 94 convertible 3.8
Old 06-20-2007, 09:14 PM   #3
STANGSUSPENSION
Former Sponsor
Send a message via AIM to STANGSUSPENSION
There is two options for you...
1. move the ebrake cable slightly...
2. get new shocks in the rear (which will improve the ride and help prevent some of the rubbing).
If you have a 94 with OEM shocks, guaranteed... 100% they are worn and you should get new shocks...
Sincerely,
STANGSUSPENSION is offline   Reply With Quote
Old 09-01-2007, 02:42 PM   #4
AndyV1
I am having the same problem with my 94 v6. I have already replaced the shocks and have pulled the springs they are 13 free length (uncut)and 150lbs spring rate. The bushings show there age but shows no excessive signs of wear. With car at ride height there is less then 2" clearance at the pbrake bracket. I looked at both motor mounts and the trans mount look fine also. I am really stumped on this one.
AndyV1 is offline   Reply With Quote
Old 09-05-2007, 03:25 AM   #5
STANGSUSPENSION
Former Sponsor
Is this with an aftermarket driveshaft? The car is not lowered? By your description it seems you still have stock springs?
Old 10-16-2009, 12:26 PM   #6
mossimo278
mossimo278's Avatar
Vehicle: 1994 Ford Mustang GT
Send a message via AIM to mossimo278 Send a message via Yahoo to mossimo278
Dont know if anyone is still looking for information on this, but I had this problem with 2 94 GTs the tack welds on the e-brake cable bracket break and the bracket bends down and rubs on the drive shaft when the suspension is loaded. I had it welded back multiple times on my 5-speed, but the auto I just hammered it up out of the way and I dont use the e-brake unless absolutely necessary... If i do use it I have to hammer it back up to get it to quit rubbing.
mossimo278 is offline   Reply With Quote
94, bracket, brake, cables, drive, driveshaft, ebrake, emergency, gt, mustang, rubbing, shaft
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
