Go Back   MustangForums.com > Vendors & Sponsors > StangSuspension.com
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-13-2008, 08:33 PM   #1
ybnormal
ybnormal's Avatar
Vehicle: 2007 Ford Mustang GT
Default what are your suggestions 4 my 07gt
I ve got a weekend driver, might see the track 1-2 times a year for fun, Ive got a cervinies side exhaust kit which severly limits my drop esp in rear. I had the frpp springs but it put my exhaust to low so I swapped to steeda springs. (I do like there products)and like the blue or black suspension colors.
I need a better plan for my suspension setup. Car is mostly stock auto ,gears but will have a SC within the year. I live out in the country where most of my driving is on narrower, crested roads, What would be the best thing suspension wise to work towards.? should I stick to the steeda stage paks or should I mix in match. thanks for your help. My clearance right now is 2 3/4 inch. from the pipe to the ground. I ve welded on ss wear plates to save theex pipes. Mytires are 19 295 35 on back 245 40 up front. the only suspension mod so far are the springs and car has 6000 miles on it.
__________________
Hey YB NORMAL-?
Member: Mustang club of america and SEVMC @ www.sevmc.org
2007 GT Vista Blue/Silver STock (not any more )
Va. Mustangs
www.cardomain.com/ride/2894288
ybnormal is offline   Reply With Quote
Old 03-13-2008, 11:17 PM   #2
STANGSUSPENSION
Former Sponsor
Send a message via AIM to STANGSUSPENSION
Default RE: what are your suggestions 4 my 07gt
I want to get this right... are you wanting to remove the Steeda springs now? or keep the Steeda springs.... then build onto that?
STANGSUSPENSION is offline   Reply With Quote
Old 03-14-2008, 06:42 PM   #3
ybnormal
ybnormal's Avatar
I want to keep the steeda sport springs and build on this, Even though they are low.
thanks, sorry for the confusion. I just took off the frpp springs.
__________________
Hey YB NORMAL-?
Va. Mustangs
Old 03-17-2008, 03:03 AM   #4
STANGSUSPENSION
Former Sponsor
You do not necessarily have to go with any kits, you can install products in stages.
The best thing I'd recommend with your setup would be shocks & struts. A good set of shocks & struts for your Mustang will make a huge difference. The Tokico D-spec shocks & struts are an adjustable setup, and is the most popular set we sell for the 2005-2008 Mustangs. Here is a link to the D-specs http://www.stangsuspension.com/store...?idproduct=794
On top of that I'd definitely install some strut mounts. Have you had an alignment yet? Were they able to get the camber back into spec after lowering? If not you may want to look into some strut mounts to help with this. Strut mounts both help align the car, and provide a more solid mount for the front end. Check out the Steeda strut mounts... http://www.stangsuspension.com/store...idproduct=1230
It sound slike you do alot of curvy/handling type of driving, rather than drag racing. So you may want to look into swaybars. Swaybars will help reduce body roll, without stiffening up the suspension too much. Check out the Steeda swaybar kit http://www.stangsuspension.com/store...idproduct=1287
Sincerely,
Old 03-26-2008, 05:27 PM   #5
ybnormal
ybnormal's Avatar
thank you Josh I will be ordering some of this soon What is the coupon code for This.
thank you again, my car had a 4 wheel alignment and they were able to get everything back in specs and my rear end did not go out of wack.
Will let you know how things worked out, thanx
__________________
Hey YB NORMAL-?
Va. Mustangs
Old 03-26-2008, 09:15 PM   #6
STANGSUSPENSION
Former Sponsor
I sent over a PM response.
Sincerely,
Old 04-15-2008, 11:35 PM   #7
ybnormal
ybnormal's Avatar
Thanks I am working on my suspension, as money comes in. Will put it all in at once.
__________________
Hey YB NORMAL-?
Va. Mustangs
Old 04-22-2008, 12:28 AM   #8
MartyMoose
Quote:
ORIGINAL: STANGSUSPENSION
Sincerely,
I've got the D-specs and Eibach Pro Kit scheduled for installation on Thursday (3 days away) but I didn't get the strut mounts. I don't know the mechanics of the strut assy so can these be installed without having to compress the springs? The reason I ask is to determine wheather I cando it in my driveway or if I'll need to take it it (I know I'll need to take it in anyway for the alignment).
Thanks, I appreciate you guys being here.
__________________
'07 GT Saleen/JDM Stage 1
Pics
MartyMoose is offline   Reply With Quote
Old 04-24-2008, 08:42 PM   #9
ybnormal
ybnormal's Avatar
I can answer that I think! You would have to compres the front springs to install the upper strut mounts (do you mean like the steeda upper mounts ?) You could still do this in your driveway, you take the strut off your car and then use a spring compression tool to squeeze the springs usually on to sides then you can take off the nut.
I hope this haelps you. I have done it several times now and it gets quicker each time. taco bill has some great How to for doing some of this stuff.
But you could do all your stuff yourself. hell your donald duck!!! good luck
__________________
Hey YB NORMAL-?
Va. Mustangs
Old 04-25-2008, 05:31 AM   #10
STANGSUSPENSION
Former Sponsor
Sorry for the delayed response (on vacation right now). YBNORMAL is correct, you do have to compress the spring to install the strut mounts.
Sincerely,
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
