Go Back   MustangForums.com > Vendors & Sponsors > StangSuspension.com
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-11-2008, 02:31 PM   #1
MustangMike2001
MustangMike2001's Avatar
Vehicle: 2001 Mustang V6
Default What to change after 1.5" drop
It's just my daily driver that might see the drag strip once or twice so I don't reallyneed the works. I would like toget my steering straitened back out though and maybe some better bushings. Suggestions would be great.
__________________
MustangMike2001 is offline   Reply With Quote
Old 04-11-2008, 06:55 PM   #2
STANGSUSPENSION
Former Sponsor
Send a message via AIM to STANGSUSPENSION
Default RE: What to change after 1.5" drop
A few things I'd suggest after lowering your car...
[ol][*]Caster/Camber plates - for correcting alignment, primarily negative camber issues (tires leaning inward)[*]Bumpsteer kit - for correcting bumpsteer caused by lowering the Mustang[*]Shocks & struts - to improve ride quality, and help dampen the higher spring rates[/ol]
Sincerely,
STANGSUSPENSION is offline   Reply With Quote
Old 04-12-2008, 01:20 AM   #3
MustangMike2001
Do I need the cc plates to be able to use the bumpsteer kit? I don't have those but I have the cam bolts I bought from you.
__________________
Old 04-12-2008, 04:21 PM   #4
STANGSUSPENSION
Former Sponsor
No, you can use the bumpsteer kit by itself. The installation of a bumpsteer kit is independent of caster / camber plates.
If you have camber bolts, and they're doing their job, then it should work out for you!
Sincerely,
Old 04-13-2008, 07:46 AM   #5
MustangMike2001
If I were to get the Steedax2 ball joints would'nt that lower the control arm "eliminating" the need for the taller tie rod ends and sway bar post?
__________________
Old 04-14-2008, 02:52 AM   #6
STANGSUSPENSION
Former Sponsor
While the X2 balljoints do help correct steering geometry and front end handling, nothing works as well as a bumpsteer kit.
Infact, Steeda recommends their bumpsteer kit as well, in addition to the X2 balljoints.
IF you want to install one mod, to help correct bumpsteer the most, install a bumpsteer kit. Steeda makes a great kit, part # 555-8104.
Sincerely,
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
