RE: long list of questions/problems...
As far as correcting camber, your #1 solution would be installing a good set of caster / camber plates. CC plates will allow you to get your Mustang back into spec by giving you a much larger adjustment range to work with.
Shocks & struts are just as important as plates. New shocks will help dampen the higher spring rates and rigors of installing lowering springs. Your stock Motorcraft shocks are marginal at best, so installing aftermarket shocks will vastly improve your ride quality.
Sincerely,
