Go Back   MustangForums.com > Vendors & Sponsors > StangSuspension.com
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-25-2008, 06:12 PM   #1
tombo9876
Default steering rack bushings
what would be a better choice (car has bilstein shocks/struts all around and h&r race springs with MM c&c plates)
MM Aluminum Rack Bushings (Stock K-Member) - 1984-2004 Mustangs or Prothane Standard Rack Bushings (Non-Offset) For 85-04 Mustangs
im also getting Prothane Front Swaybar Endlink Kit 5 inch - 94-04 Stock Ride Height, Prothane Front Swaybar Bushings 27mm - 79 GT, 98 V6, 99-04 GT, and the Steeda Front End Bumpsteer Kit - For 94-04 Mustangs
__________________
98 v6
-big k&n air filter, true dual exhaust w/ flow 40s, split port swap w/ 24# injectors, comp cam, p&p heads, tuned w/ xcal2 by vmp, ud crank pulley, bilstein struts/h&r race springs/ mm c&c plates, spec stage 1 clutch, mgw sts, mach1 wheels
tombo9876 is offline   Reply With Quote
Old 04-26-2008, 07:48 PM   #2
STANGSUSPENSION
Former Sponsor
Send a message via AIM to STANGSUSPENSION
Default RE: steering rack bushings
The MM Aluminum rack bushings are some of the most affective rack bushings we sell. They will tighten the steering response considerably.
The offset bushings do very minimal to correct bumpsteer. The Steeda Bumpsteer kit will do that job much better.
If you're getting the Steeda bumpsteer kit, go with the MM Aluminum rack bushings.
Sincerely,
STANGSUSPENSION is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
