RE: What Struts and Springs do I Need
I can answer your questions...
1. On the H&R springs, the springs will work fine with the Fox Body. They may raise the front end of the car more than the expected drop, but they will work fine. Remember the Fox is lighter than a normal 99-01 Cobra. You can try playing with the front spring isolator arrangement to acheive the exact drop you want.
2. With SN95 spindles, you can pretty much use any 87-04 Strut. The spindle mounting size for the strut only really changed from 86 and previous. With Bilstein, just go with the standard V36-4138-H3 part, with Tokico, go with the HB3026 part.
Sincerely,
