New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Vendors & Sponsors > StangSuspension.com
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-11-2008, 08:43 PM   #1
Sinbad1769
Default Lowering springs
Hey there! looking to lower my 96 gt coupe 1.5''. dont really know which is better over another but was wondering if ur 2 cents would help.
Also was reading somewheres and came accross needin CC plates when lowering your car 1.5 and lower.
If you could fill me in on some information about which u recomend and why id appreciate it greatly. thanks
Sinbad1769 is offline   Reply With Quote
Old 11-12-2008, 02:21 PM   #2
STANGSUSPENSION
Official Site Sponsor
Send a message via AIM to STANGSUSPENSION
There is no "better", it all depends on how much you want to drop the car (1.5 inches) and what type of driving you'll be doing.
If you want a 1.5 inch drop, and its basically a street car, I would go with the Eibach Pro-Kit lowering springs http://www.stangsuspension.com/store...p?idproduct=82
You will need CC Plates when lowering. Lowering the car adds negative camber (tires leaning inward) which will cause inner tire wear. CC Plates solve that issue. Here is a link http://www.stangsuspension.com/store...?idproduct=478
If you still have the original shocks and struts in the car, that is another strong suggestion.
__________________
StangSuspension.com
STANGSUSPENSION is offline   Reply With Quote
Old 08-11-2009, 02:02 PM   #3
CCMPower
Vehicle: 1996 Mustang GT
Default I also have a 96 GT
I have another thread on this forum as well and am in the process of getting all of the information possible. I've narrowed my search down to the FRPP "B" springs. I was originally thinking about the "C" springs but only wanted to stiffen the chassis up a little more than stock and lower it just a little bit too. I think the "B"s will bring it down roughly 1" all around. I wanted to keep this as low cost as possible so for now I wasn't planning on changing out the shocks or struts. Is is still possible to do this without having to get the caster camber plates? Thanks for any info.
CCMPower is offline   Reply With Quote
Old 08-22-2009, 12:37 PM   #4
reznap
reznap's Avatar
Vehicle: '00 laser GT auto
Send a message via AIM to reznap
Everything I've read, lots of it here, says lowering an inch or less is negligible and won't require CC plates.
To be safe, keep an eye on the inside of your tires.
__________________
flowmaster 40s, k&n rai, bbk 78mm tb/p, accel cops, ngk plugs, steeda udp,
low temp stat, full length welded sfc, bbk st brace, hypertech tuned...
dropped about an inch with some appearance crap & just sits in the garage.
reznap is offline   Reply With Quote
Old 10-12-2009, 09:04 PM   #5
shawnf22
i have the h&r supersport springs (2" drop) and i couldnt be more happy with the drop, i rarely scrape at all, sometimes my exhaust but nothing serious, i went with caster camber plates but i think i should have just went with the springs and checked the tires first because it was a very minor adjustment
shawnf22 is offline   Reply With Quote
2, drop, frpp, lowering, mustang, springs, stang, suspension
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
