Steeda Adjustable Panhard Bar - 05-13
Check out our new video on our Steeda adjustable panhard bars!
These are a great idea to get, whether you are running stock springs or especially if you are running lowering springs.
Please let me know if I can help you with anything.
Steeda Adjustable Panhard Bar - 05-13 - $167.95
A great step towards improved handling out back is to upgrade the panhard bar supplied by the manufacturer with our chrome-moly steel unit.
Steeda's panhard rod features 4130 chrome moly alloy steel construction, not just ordinary mild steel like the factory piece and other aftermarket offerings. Benefits include length adjustment to adjust rear end offset and urethane bushings for reduced flex.
In keeping with Steeda's motto "Weight is the enemy of performance" Steeda's panhard rod is 5lbs lighter than the stock unit. And to make a good thing better, add our heavy duty Panhard Bar Brace.
Our Panhard brace stiffens the panhard bar mounting bracket which is prone to under load during cornering and provides some extra chassis rigidity as well.
Not sure if you need to replace the factory panhard bar brace? Put your car in the air and grab the factory brace and pull on it. You will be able to flex it by hand!
Like our panhard bar our panhard bar brace is made of super strong 4130 chrome moly alloy steel for the ultimate in strength!
Product Benefits
Product Benefits
- High quality construction
09-24-2015 09:18 PM
