Steeda Autosports Steeda Autosports is Ford's #1 aftermarket performance parts manufacturer. Steeda's parts are manufactured to ISO-9001-2000 standards and are thoroughly tested and proven on race tracks and on the street. Specializing in suspension and performance parts. Steeda also carries a variety of outside vendor products making Steeda your one stop shop for performance!
Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) - Now Available!
Old 03-03-2015, 07:08 PM
tj@steeda's Avatar
Default Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) - Now Available!
And yet another upgrade rolls off the assembly line here at Steeda! Our Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) are in stock and readily available!
These S550 integral/vertical links are made from 6061, aircraft grade aluminum. They feature CNC machined delrin bushings, and billet steel bushing sleeves and spacers, providing less deflection than the rubber bushings in the stock vertical links, yet does not add any NVH!
Our Steeda vertical end links will not flex under load like the OE links, and will give a better feel of the rear suspension, which helps the rest of the suspension assembly perform as it should. The install is simple and comes with all necessary hardware!
Key Product Benefits:
- Provides better handling characteristics
- Installs easily, with basic hand tools
- Will not flex under load
- No increase in NVH
- Made in the United States with high grade materials
Product Photos (the second to last one compares ours to OE):
Best Regards,
TJ
tj@steeda is offline
Granatelli Sales
01-20-2020 12:34 AM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
stark777
09-21-2015 12:46 PM
09-16-2015 07:53 PM
mdj89
09-09-2015 04:04 PM
Quick Reply: Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) - Now Available!
