Go Back   MustangForums.com > Speed Zone > Street/Strip
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-12-2008, 03:46 PM   #241
tspence45
1994 Chevrolet Camaro
Default RE: LS1
^^^^I do happen to love my torque curve a lot. lol. I'll figured out if a true dual setup sounds amazing on an LT1 hopefully late next week. My Pacesetter LT's came last week and my single chamber mufflers, o2 extensions, and EGR blockoffs should be hear early next week. Then, on to the exhaust shop I go. I'll make sure to post some sound clips in here, if I can find a good camera.
__________________
98 Trans Am M6-Lid, SSRA, LT's, O/R H-pipe, Hurst Billet/Plus STS, LCA's, PHB, and DR' LS6 intake manifold and tune coming soon)
http://www.cardomain.com/id/tspence45
tspence45 is offline   Reply With Quote
Old 07-19-2008, 11:28 PM   #242
empatho
Default RE: LS1
Differences between F-bodys
1998 F-Body
1. Had different casting heads which had perimeter bolts and valve covers.
2. Ignition coils were mounted to the valve covers one at a time.
3. The water temp gauge actually works.
4. 98's do have an oil life monitor, they just don't tell you anything when its time for a change. You can find it in Auto-Tap
5. WS6s had single outlet exhaust (all others had duals)
6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
7. Only year that Purple, Gold, and Green were available
8. Some very early Trans Ams came with LT1 style headrests
9. Rear hatch release was poorly designed and often caused problems releasing mechanism
10. Early model 98 Monsoon stereos didn't have capability to control 12-disc CD changer
11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT (wide open throttle) faster than 2000+ cars
13. 1998 cars had 28 lb fuel injectors from the factory
14. 1998-2000 cars had a larger cam than the 01-02 cars
15. 1998-1999 cars had more restrictive exhaust manifolds
16. 1998-2000 cars had an LS1 intake with EGR
17. 1998 and some early 1999 cars had blue outside rear view mirrors (Trans Am only)
18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
19. Last year F-body to use the old 15.5 gallon steel fuel tank.
20. Only year LS1 F-body to contain a gas cap with a tether long enough to actually hang from the fuel door while open
21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
23. 1998 most cars did not have an idle adjustment screw on the throttle body. Some 98 cars do have the idle throttle stop set screws.
24. 1998 cars have a completely different PCM from 99+ cars
25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
26. 97-98 LS1's used a paper water pump gasket. The only gasket that isn't reuseable
27. SSs did not ALL go to SLP starting in 98. Y2Y was the RPO code that sent them to SLP for additional options
28. SS option did not "include" the Synthetic oil package, it was a SLP only Option
1999 F-Body
1. 1999-2000 cars switched to 26 lb fuel injectors
2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
5. 1999 cars continued the LS1 intake with EGR provisions
6. 1999 cars continued more restrictive exhaust manifolds and larger cam
7. Only year that Hugger Orange was available (Camaro only)
8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
9. Switch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
11. Company wide change added black boxes to record up to 5 seconds of data before a crash
12. Rear hatch release was redesigned with stiffer spring that released the hatch better
13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
17. 1999 there was the color "Medium Blue Metallic" which was available on both the Camaros and Firebirds. Only one year of that color
2000 F-Body
1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
3. Added rear child seat safety hooks to interior per federal requirements
4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
5. Camaros got redesigned 10-spoke base rims, and SSs came with new 10-spoke rim design
6. First year of Monterey Maple Metallic paint
7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
8. Cloth interior cars got new rainbow colored cloth patterns
9. Camaros only got the Pontiac steering wheel with optional audio controls
10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
12. The last year a WS6 Formula was offered
13. Starting 2000 intake lids contained a seperate breather filter
14. 2000+ Camaros came with body colored mirrors instead of black ones like 98-99
2001 F-Body
1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SSs
4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
6. WS6 cars had a redesigned 5 spoke rim which was more wavy
7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
8. Manual transmission cars all came with the Z06 clutch
2002 F-Body
1. 35th Annivesary edition of the Camaro, and Collectors Edition Trans Am available
2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car they're installed on
3. 2002 cars continued with the LS6 intake, 28 lb fuel inectors and smaller truck cam
4. 2002 continued the use of an LS6 block in some LS1 F-bodies
5. A factory supported optional 345 HP option could be ordered from SLP
6. Manual transmission cars continued use of the Z06 clutch
7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
__________________
2002 Z28 Auto (3.23 gears)
Mods
Lid, UD pulley, Shift Kit, 160 Thermo, Y-pipe, Panhard, TB bypass, P&P TB, Bellow, K&N, Strut Brace, Flowmaster, weight reduction
empatho is offline   Reply With Quote
Old 07-19-2008, 11:42 PM   #243
MrRogers
MrRogers's Avatar
Vehicle: 2006 Corvette Z06
Send a message via Yahoo to MrRogers
Default RE: LS1
Source?
__________________
2007 Tahoe
C6 Z06
2009 CLS 63 AMG
ZR1 coming soon...
MrRogers is offline   Reply With Quote
Old 07-20-2008, 12:52 AM   #244
empatho
Default RE: LS1
I remember reading it on LS1tech.com or LS1.com a few months ago and I just saved it on my comp, If you guys go to one of those forums you will find allot of info.
__________________
Mods
Old 07-20-2008, 02:08 AM   #245
S8ER01Z
2001 Chevrolet Camaro
Vehicle: 2001 Camaro Z28
Default RE: LS1
Quote:
ORIGINAL: MrRogers
Source?
Main Source Article...
http://ls1tech.com/forums/showthread.php?t=213148
Differences between the years...
http://www.ls1tech.com/forums/showpo...mp;postcount=2
__________________
2001 Z28 M6 - 13.1 @ 108mph 2.1 60ft / Bone Stock
3600lbs Race / 3440lbs Curb - 322rwhp/341rwtrq (1LE Springs/FRA/LID)
S8ER01Z is offline   Reply With Quote
Old 07-20-2008, 10:55 AM   #246
empatho
Default RE: LS1
there you go that's what I was talking about I just felt 2 lazy to look for them[8D].
__________________
Mods
Old 07-20-2008, 12:35 PM   #247
lowram00
Default RE: LS1
I LIKE A LS2
lowram00 is offline   Reply With Quote
Old 07-27-2008, 04:11 AM   #248
N20LT4
I ♥ Acer
Default RE: LS1
I just wanted to express my point of view of what's been said about the LS1 cars. My old 2001 SOM WS6 M6 put down 305.2rwhp and 314.8rwtq on 2/16/07 in complete stock trim with 63k miles on the clock. After multiple runs I bested 13.2/107.4 with a 2.0 60' in stock trim, the car ranconsistant 13.50s-13.20s at 106-107. I raced several stock or lightly modified S197 GT's and never lost. I did infact lose to a pullied '06 Roush and a cammed/bolt-on S197. My friendsstock (at the time) 2006GT M5for comparison put down 267rwhp andbested 13.8/103.Hepretty much ran consistant high 13's. I wouldpull him byabout 4-5 carsstock for stock every time so I can never say an S197 and an LS1 M6 (w/ a good driver) is a drivers race. Not to say he is thebest driver, but majority of the stock S197 cars i've seenhave been in the13.7-13.9 range here at Sea Level.The problem is you have a lot of F-body guys that can't launch a 6-speed car for sh*t.Therefore I have seen instances where the Mustangdriver simply outdrives theLS1 car. But if you look at it from a power-to-ground perspectiveit is plain reality that an LS1is significantly faster.My buddies Mach 15-speed was a better match for mein stock form, as he wasrunning 13.40-13.50'sat 103-104mphin stock form,but I would still get him by 2-3 cars though. I ended updoing a Vindicator2 (240/244 608"/598" 112) cam from Vengeance Racing, Ported TB/MAF, Lid, Kooks 1-7/8"long-tubes, X-pipe, 3" True Duals,and a HP Tuners tune and made 437RWHP cam-onlyand ran a best of11.03/122.1with a 1.50 60'.
N20LT4 is offline   Reply With Quote
Old 10-08-2008, 09:35 AM   #249
craz1469
The Y-pipe design is what destroys the sound on an f-body, an vette sounds much better because of the x-pipe. But mustangs do sound smoother.
__________________
craz1469 is offline   Reply With Quote
Old 10-09-2008, 02:20 AM   #250
tspence45
Quote:
Yeah. The x-pipe really made my car sound like a whole different animal. But, still not as smooth as a 2v or 4v. They only sound smooth because it's an H-pipe, though. Once you get into catless H-pipes or catless X-pipes on the mod motors, they don't sound nearly as smooth as stock.
__________________
2800, cam, camaro, carburetor, cutout, exhaust, fbodies, fbody, gen, ls1, ls2, memphis, rattiling, stall, stock, underrated
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
