Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Spanked the neighbours GTO LS-2
Old 10-16-2007, 03:19 AM
ravenforbidden
ravenforbidden's Avatar
Default Spanked the neighbours GTO LS-2
The gears must be really bad on the GTO because when he nodded ya to the race and we went from the light, well I took it runnin ya know full throttle power shifting like m f and he just seemed to be lost or something.
my numbers are this, due that I'm to lazy to update my parts on my sigi forgive them for being inaccurate, but who'd win in this case...
my dyno run yeilded,
350hp at 6k rpm, and 375 ft lbs at 3.5k rpm I'm using a T5 and no weight removed, basic upgrades like CAI and Manifold exhaust all done.
ravenforbidden is offline
Old 10-16-2007, 03:26 AM
moosestang
moosestang's Avatar
Default RE: Spanked the neighbours GTO LS-2
GTO's are heavy, especially compared to your car. Plus their IRS = wheel hop so you would out launch him every time. He might be putting down 30 more hp to the ground if he's stock.
Not sure what gears they have.
moosestang is offline
Old 10-16-2007, 03:33 AM
05Stang4Me
05Stang4Me's Avatar
Good kill....I am going to have to try a GTO sometime. I see a few around here but have not had the a chance to line up on one yet.
05Stang4Me is offline
Old 10-16-2007, 07:07 AM
NYstang
MF Staff Snitch
NYstang's Avatar
are those numbers to the ground? a stock LS2 pts down around 340 whp and 350-360 rwtq when they are stock, for the manual
NYstang is offline
Old 10-16-2007, 08:04 AM
cacimar
cacimar's Avatar
good kill man, the gears are 3.46 i think. Was his car stick shift?GTOs are fast cars but notunbeateable, many people seem to forget that and they get stuck up. The manual trasmission are harder to launch than the automatics so an inexperience driver will probably run 14s on that car
cacimar is offline
Old 10-16-2007, 08:21 AM
stangman94
stangman94's Avatar
ORIGINAL: ravenforbidden
What do you mean by basic upgrades because even with an excelent hci u wont see 350 and 375 to the wheels? Are you stroked to a 331 or somthing?
stangman94 is offline
Old 10-16-2007, 08:35 AM
S8ER01Z
S8ER01Z's Avatar
Unless you forgot to add a lot of mods I don't see you making 350 crank over otherwise.... In fact H/C/I I would be surprised if you made 350 crank.
I know people with H/C/I that are barely make 270rwhp.... How about a little more info on your setup???
S8ER01Z is offline
Old 10-16-2007, 10:01 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
dont listen to a word that kid says.........if you dont believe me look at his post history.[:'(]
FivePointOhh is offline
Old 10-16-2007, 10:05 AM
drhoward
Penis Mod Erator
drhoward's Avatar
ORIGINAL: S8ER01Z
most guys make 300 plus with a decent hci swap and a tune, but 350 is very high unless he has some sort of forced induction or a stroker,otherwisethere is no way a 5.0 will put down that much power
drhoward is online now
Old 10-16-2007, 10:35 AM
S8ER01Z
S8ER01Z's Avatar
ORIGINAL: drhoward
ORIGINAL: S8ER01Z
most guys make 300 plus with a decent hci swap and a tune, but 350 is very high unless he has some sort of forced induction or a stroker, otherwise there is no way a 5.0 will put down that much power
Good points...a lot of people here go small on cam (daily driving) and rarely have tunes. Makes sense. 350 is a stretch in a half though... I could see 300ish rwhp H/C/I + boltons...
S8ER01Z is offline
Quick Reply: Spanked the neighbours GTO LS-2
