Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
First time out- 04 GT
Old 08-23-2008, 11:02 AM
max427
max427's Avatar
Default First time out- 04 GT
went to atco last night, only got two runs in and wasnt happy with either
my first run i left traction control on, not realizing, so it ruined my burnout and my 60 foot
RT- .565
60- 2.244
1/8- 8.717 @ 85mph
1/4- 13.297 @ 106
my second run i remembered to turn T/C off, but still need to get a better burnout. i tried dumping the clutch then getting on the brakes to burnout, but i think i got on brakes to hard or something. tires def didnt get hot enough
RT .440
60- 1.9
missed third, wouldn't go into fourth, so i coasted the rest of the way
1/4- 16.867 at 85mph !
i always miss third! what the hell is wrong with me. Im buying a shifter and hoping that'll help me a little. i have to be doing something wrong theres no reason i should miss third so consistently lol.
max427 is offline
Old 08-23-2008, 11:28 AM
jimkaray
jimkaray's Avatar
A shifter will help but also try moving your seat up as far as you can while still being able to shift comfortably. A little cramped is ok, you want to minimize the distance your leg and arm travel while maximizing your reactions and strength.
jimkaray is offline
Old 08-23-2008, 12:15 PM
cacimar
cacimar's Avatar
not bad but you should be in the 12s with those mods for sure
cacimar is offline
Old 08-23-2008, 12:30 PM
BolognaPony
BolognaPony's Avatar
You need tires.
I cut a 1.7 60 foot an ran a 7.9 with 1 mph faster one ET Drags with basically the same mods you have.
Wait...omg....did cacimar just admit a light bolt-on GT with a 100 shot should be in the 12s?
BolognaPony is offline
Old 08-23-2008, 12:55 PM
cacimar
cacimar's Avatar
Originally Posted by BolognaPony
You need tires.
12s should be no problem, but claiming you run low 12s without acutally running it is stupid kid. Should i claim my car is mid 11s high 11 second car just because of BIG Turbo ehhhhhh NO!!! IT IS NOT A 11 second car until i run that is that simple
cacimar is offline
Old 08-23-2008, 02:07 PM
max427
max427's Avatar
Yeah shifter will be ordered monday. Tri-ax with FRPP **** from AM.
I need tires? no way, driver mod possibly. Im running 315 nitto D/R's that are brand new. I just cant drive. I ran 20 psi in the rear and launched at 4000k or a little higher. I need burnout advice.
When i tried the burnout i dumped the clutch and got on the brakes, but i was nervous being my first time out and that probably had a lot to do with it, i was only in a burnout for a split second. And my first run i had traction control on so there was no burnout.
Do you need a line lock to do a good burnout with a stick shift?
is there a better shifter than the steeda tri-ax i should look at?
thanks for quick replys guys!
max427 is offline
Old 08-23-2008, 02:08 PM
max427
max427's Avatar
btw driving on a drag strip feels so much faster than on the street. (also my second run, the 16 second one, i still beat the 240sx i was running against haha)
max427 is offline
Old 08-23-2008, 02:25 PM
BolognaPony
id be highly suprised if you ran any better than a 1.9 60 foot on those ****tos.
Nitto drags have nothing on a good set of ET Streets or ET Drags.
I mean i run 8.60s on motor with et drags to your 8.7 on a 100 shot, that should show you the lack of traction right there.
Old 08-23-2008, 02:38 PM
max427
max427's Avatar
but my issue is getting a good burnout and obviously not missing a gear. Also i dont think it was lack of traction as much as leaving T/C on screwed that me up the worst. I'll hit the track again soon and hopefully get a clean run in. i should be in 12's
i could see going to ET drags if i didnt just buy nitto drag radials.
max427 is offline
Old 08-23-2008, 02:40 PM
BolognaPony
woh wait, you left the TC on when spraying nitrous?
Thats a big nono.
You should still be able to get into the 12s on the nittos.
You still have factory rear gear?
Rev it up and do a nice smokey burnout until you hear your tires screech, then they are hot enough. Find the launch where you are spinning just a hair or chirping and taking off. If you are running a factory rear end and you dead hook it, goodbye axle.
Quick Reply: First time out- 04 GT
