Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
back to strip at 22 lbs boost
Old 11-03-2008, 05:43 AM
forensicsteve
forensicsteve's Avatar
Default back to strip at 22 lbs boost
First time back to strip at 22 lbs (previous was 20) and alcohol injection system. Car only made 3 full race passes, before plugs gave out (didn't look too good before racing). Slips show two back to back passes (#289)
forensicsteve is offline
Old 11-03-2008, 06:22 AM
jmdgto
jmdgto's Avatar
nice times.
jmdgto is offline
Old 11-03-2008, 10:29 AM
TRBOPWR
TRBOPWR's Avatar
Very nice. Definitely got some 9's in it with that kind of trap. Street driver?
TRBOPWR is offline
Old 11-03-2008, 10:39 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
With the alcohol injection, I could see that being a pump gas, streetable setup.
35thAnni99GT is offline
Old 11-03-2008, 10:49 AM
mikeysGT
mikeysGT's Avatar
great times! would love to have that kind of power and times at the track!
mikeysGT is offline
Old 11-03-2008, 11:47 AM
1.5LofFury
1.5LofFury's Avatar
consistent much??? great times btw!
1.5LofFury is offline
Old 11-03-2008, 01:40 PM
AmericanSpeed
AmericanSpeed's Avatar
Awesome times, but I bet it was frusterating to be knocking on the single digits door like that without getting it.
AmericanSpeed is offline
Old 11-03-2008, 07:10 PM
forensicsteve
It has limited street use. I live half a mile from work. Drive it there sometimes and to local car shows. Full spool and cage make for an awkward drive. Parallel parking is impossible. But it has electronic overdrive, so can go highway speeds without burning up transmission. It's set up for bracket racing with transbrake, 2step, and delay box.
It just had its first full racetune with alcohol inj sys and went to the track for datalogging. The 100% methanol dropped IATs 150 degrees. Tuners are sponsoring car in a big event next month, so we'll be sorting out a few glitches.
We only got to 21 degrees of timing before fouled plugs ended evening. Plan is to go up to 30 degrees but stay at 22 lbs boost. Don't think intake manifold will take anymore boost. Lance (strip driver) won't have race license or chassis cert by then, so have to keep it in the 10s for the event.
Some vid from saturday
http://s149.photobucket.com/albums/s...110108prep.flv
http://s149.photobucket.com/albums/s...=110108run.flv
Old 11-05-2008, 04:38 PM
2005mach1
2005mach1's Avatar
great job come on 9's
2005mach1 is offline
Old 11-05-2008, 05:30 PM
Solitear
Solitear's Avatar
Nice times, man you must be wanting that 9'sec time slip badly so close yet so far GL and if you get a 9 make video and post or i'll cut you! ^^
Solitear is offline
musnicki
09-23-2015 07:11 AM
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
gus_vb
08-29-2015 11:35 PM
Black_GT_02
08-20-2015 01:26 PM
Quick Reply: back to strip at 22 lbs boost
