Go Back   MustangForums.com > Speed Zone > Street/Strip
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-09-2009, 01:51 AM   #1
Intervention
Intervention's Avatar
Default Finally broke 12's - Question on ET Streets
Track was not really prepped at all, outside air temp was around 38f
My best run was :
1.858 60 ft
5.416 330ft
8.308 1/8th
85.48 1/8mph
10.785 1000ft
12.868 1/4
108.38 mph
This WAS going to be my best pass until I let off around the 1000' cause of the swerving due to bis ply tires
1.891 60 ft
5.395 330ft
8.270 1/8th
85.72 1/8mph
13.025 1/4
96.68 mph
This was my first time out with sticky tires. I am using(bought on craigslist) MT ET Streets 26x11.5x17 on stock GT rims. My first 3 passes were around 14psi. I wanted it to be higher, but my track did not have their air pump out yet. Anyways, the 3rd run, it was floating very badly around the 1000'. I let out of it in fear ofm losing control. Afterwards, I drove to the nearest gas station and put in 18psi total.
Made a few more passes. It did not hook quite as good, but the floating was reduced. It is still there though. But from what I hear this floating is normal?
__________________
2007 Mustang GT ~ Alloy Clearcoat Metallic
Mods: * JLT CAI w/ Custom 93 octane tune * Hotrod Cams * Spydershaft * Centerforce DF * Ford Racing 4.10's * MGW Short Shifter* Stinger Exhaust w/ High Flow Cats * CMCV Delete Plates* J&M LCA * Tuned by Performance Dyno * 310whp / 311wtq
Intervention is offline   Reply With Quote
Old 04-09-2009, 02:03 AM   #2
fazm
2005 Ford Mustang
Send a message via AIM to fazm Send a message via Yahoo to fazm
congrats on the time, and yes its normal.
get some bias ply front runners and it will help a little
__________________
2005 v6 mustang, just cant afford 8 cylinders
fazm is offline   Reply With Quote
Old 04-09-2009, 02:08 AM   #3
Intervention
I am going to try to sell these ET Streets in hopes of picking up some ET Radials.
Last season I made 3 passes with the radials. I didnt do nearly as good with them, although that was on stock LCA's and the wheel hop was appallingly bad.
__________________
Old 04-09-2009, 03:55 AM   #4
bluebeastsrt
2004 Dodge SRT-4
bluebeastsrt's Avatar
Vehicle: 2004 Stage 3 SRT-4
Location: usally a state of confusion. But I live in jersey
Pretty nice slip considering the conditions. I carry one of those cheap little compressors you plug into you lighter just so I can make adjustments after each run.
__________________
11.79@118.53
BEST 60=1.68
BEST TRAP SPEED=120.60
I've never actually raced but according to my dyno numbers. I should run 8s on street tires.
bluebeastsrt is offline   Reply With Quote
Old 04-09-2009, 06:17 AM   #5
jmdgto
jmdgto's Avatar
nice times. congrats
__________________
couple of mods
jmdgto is offline   Reply With Quote
Old 04-09-2009, 07:35 AM   #6
grampa_stang
grampa_stang's Avatar
Vehicle: 2007 GT Coupe
Congrats on the new best time!
__________________
'07 GT - AT / IUP / Charcoal int / Carbon fiber dash
JLT / SCT Xcal 2 / Bama 91 Race / Eibach Pro / 3.73's
Tint / Shorty / Sequentials / Cervinis side louvers
BFG G-Force SS A/S P255/45-18 / ADR Wheels
BoomTube Crew Member
13.66 @ 100 (DA 4300')
grampa_stang is offline   Reply With Quote
Old 04-09-2009, 11:16 AM   #7
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
congrats on the times
yes bias ply do get squirmy on the big end, radials do much better
get some upgraded LCAs and that will help your wheel hop.
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is offline   Reply With Quote
Old 04-09-2009, 12:56 PM   #8
cobra443
2008 Ford Mustang
Vehicle: 2008 Ford Mustang GT
Send a message via AIM to cobra443
Good runs! I sold my bias ply after a few runs... Just didn't like them.
__________________
Derek
2008 Windveil Blue Mustang Gt 5sp.
BRENSPEED!!
11.229 @123.96 1.7 60Ft.
Paxton Crew Founder
cobra443 is offline   Reply With Quote
Old 04-09-2009, 01:28 PM   #9
2005mach1
2005mach1's Avatar
Vehicle: 2005 ford mustang GT
great time-good job
I have bias ply front and rear- Have not made any strip passes yet
but on the sreet its not that bad- I will wait and see
__________________
2005 mustang GT (1970 mach 1 clone) 4.6L 3V automatic 3.73 gears
5/8/2009 306HP/322TQ 12.55 @ 108 1.77 60 ft.
mustang owners club of southeast michigan www.mocsem.com
MOCSEM crew member
2005mach1 is offline   Reply With Quote
Old 04-09-2009, 02:48 PM   #10
AmericanSpeed
2005 Ford Mustang
Very normal. It was unnerving at first (going through the traps at 120+ with the rear end dancing doesn't feel very safe), but you get use to it. You will realize that the little bit of float is normal and not worry so much (I've been running my ET Streets at 13-14 psi). The way a radial tire reacts and the way a bias-ply tire reacts are different. Bias Ply tires react more instantly, while a radial tire has more pause before it is going react, this helps conduce the oversteer feeling.
__________________
05 Redfire GT: WHIPPLE HO @ 10psi, VMP dyno tune & other goodies - stock block, stock exhaust, stock 3.55s
11.324 @ 121.84 w/ 1.627
http://www.youtube.com/watch?v=dlBxdF5IqFM
11.36 @ 122.72 w/ 1.663
http://www.youtube.com/watch?v=BoGf6DiMVk4
Previous runs:
CAI+tune only 12.877 @ 106.79 w/ 1.819
CAI+tune+suspension 12.783 @ 108.05 w/ 1.841
both on stock tires
Please do not link companies in your sig
AmericanSpeed is offline   Reply With Quote
168, 2200sl, 26x115x17, 60ft, bias, dyno, foxbody, hp, mustang, mustangforums, ply, stock, street, streets, suspension
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
