While the R/T is nice, I like the appearance moreover on the SRT and the Obvious performance difference.
Also, people are saying there is only a 25-30 HP difference between the two?
R/T has 370HP with Auto, and 375 Manual. and 398TQ Auto, and 404 Manual. SRT is rated at 425HP, and 420 TQ, with a higher redline, better and bigger motor, etc.
Anyhow...
__________________
2003 10th Anni Torch Red Cobra 462 RWHP 486 RWTQ SAE
Fluidyne Heat Exchanger
H&R Springs
K&N FIPK
Mac O/R Prochamber and Borla Stinger C/B
BF 2.76 Pulley
LDC Chicago HCM
Many more mods
Also, How does a car with 4.10 gears do 160+, when a buddy runs out of Gear with 4.10's @ 140 and cannot rev his motor any higher?
The S197 does not run out of gear at 140 mph with 4.10s, not by a long shot. I just had my needle buried on the way to work one morning last week. My Mach with 4.10s would bounce off the 155 mph governor with lots of gear left as well.
edit... the GT is set at a 6500 rev limit, the Mach was at the stock 6800 rpm limit.
__________________
2009 GT/CS, Vapor Silver, Manual '
308.4 RWHP/317.4 RWTQ
13.18 at 107 mph (2.0 60')...(1,243' DA, 75 degrees)
8.58 1/8th at 85 mph
You have an increased Redline, that is why. My friend's GT is still set at 6250, and runs out. My friends Blown Mach 1, with 4.30 Gears, runs out around 135 MPH before he is redlining his car.
I also bet it takes a while to get to 160+ in an N/A GT without any kind of power adder and only bolt-ons.
__________________
H&R Springs
K&N FIPK
BF 2.76 Pulley
LDC Chicago HCM
Many more mods
It gets there quicker than you may think, although I'm not sure about the 160 mph part since the speedo doesn't read that high lol, but it will bury the needle within a 1.5 miles or so from a 60 mph roll.
__________________
Top speed with 4.10 and Manual Transmission in an S197 GT is about 183 with a 6250RPM Rev limit, and 190 w/6500rpm Rev limit. This is going by the math. The actual acheivable speed depends, on the amount of power you are making, if you are even able to finish 5th gear. It also depends on what size tire you are running, it will change the speed by a few mph.
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction. 11.867 @ 119.35
