Go Back   MustangForums.com > Speed Zone > Street/Strip
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-01-2009, 10:37 AM   #1
Kmelfi11
2002 Ford Mustang
Vehicle: 2002 Ford Mustang GT
Default Slicks vs. Drag Radials
im looking for a new tire and dont know which to go with. these wheels are not road driven so its all track. i heard slicks are better for your car with launching since its a softer sidewall but dont know much about negatives. i will be switching to 4.10's and want to keep it 26in tall since im n/a. http://summitracing.com/parts/MTT-3054/ thats what i think would be best for me but need some advice.
since i ran 12.8 ive done coil overs/struts, 31spline rear, rear shocks, new upper and lower control arms, no sway bar, will be removing the rear seat, summit star track wheels and 4.10's in the next few weeks and i think thats it... in all ive lost about 150lbs a little under 100 of that being wheels. with the new setup im hoping to break the 1.6x 60ft and 12.49 mark. think my goals are realistic?
__________________
Kmelfi11 is offline   Reply With Quote
Old 07-01-2009, 10:46 AM   #2
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
Slicks will hook better off the line and last longer for track use. They will feel "squishy" on the big end and may give you a feel of the rear end "floating" around.
DRs will hook nearly as well (at your power levels they should be near equal IMHO) will feel solid on the top end.
The link you have there is a 28" tall tire tho.
Here's the 26"s
http://summitracing.com/parts/MTT-3053/
http://summitracing.com/parts/MTT-3052/
What rim are you using?
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is offline   Reply With Quote
Old 07-01-2009, 01:25 PM   #3
bluebeastsrt
2004 Dodge SRT-4
bluebeastsrt's Avatar
Vehicle: 2004 Stage 3 SRT-4
Location: usally a state of confusion. But I live in jersey
I've ran both types of tires on front & rear drive cars and for a track only tire I'd go with the slick. That floating fealing STKJOCK decribed above, I only really felt when I was out of the throttle and slowing down. Thats where you really feal them float.
__________________
11.79@118.53
BEST 60=1.68
BEST TRAP SPEED=120.60
I've never actually raced but according to my dyno numbers. I should run 8s on street tires.
bluebeastsrt is offline   Reply With Quote
Old 07-01-2009, 02:58 PM   #4
Demon 340
Administrator
Demon 340's Avatar
Vehicle: 1972 Dodge Demon 340
Send a message via AIM to Demon 340
ive run both DRs and slicks in a 26x15x11.5 and with hoosier Quick time pro (DRs) and the same sized hoosier slicks, my short times were about the same...and i was running 12.30s-12.40s. the downfall to running slicks is that at many of the tracks where i have run, slick cars run in a seperate class and in that class youll likely be the slowest car. that might not matter to you but i didnt like it...my car was streetable running against cars with lexan and parachutes...
Demon 340 is offline   Reply With Quote
Old 07-01-2009, 02:59 PM   #5
Projectquick
1986 Ford Mustang
Projectquick's Avatar
Vehicle: 86 LX
Your 60s are already pretty low so with the suspension upgrades and DRs I could see you getting almost .2 of your 60' time so that is about .3 or .4 on the big end.
__________________
86 LX
bolt on cammed 5.0 with 125 shot.
351w build starting
Projectquick is offline   Reply With Quote
Old 07-01-2009, 07:00 PM   #6
Kmelfi11
2002 Ford Mustang
thanks a lot guys! and sorry was rushing to find the link post thread and head to work. i have summit star's 15x8's for the rear. slicks is the way im going, someone at the track last night was tellng my dr and i just wanted to check
.2 off the short end really ads up on the long end, didnt realize how big of a jump it was.
__________________
Old 07-01-2009, 10:54 PM   #7
Demon 340
Administrator
Demon 340's Avatar
what tires did you pull a 1.85 with? what track are those numbers from?
Old 07-01-2009, 11:08 PM   #8
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Vehicle: 4000 - 0 -.5 Yes, thats right. I tied half a race.
Send a message via AIM to JD1969
A high 12 car does not need a slick IMO. A GOOD modern drag radial will work fine and he will be able to drive it to and from the track (legally). Besides that, when I see a slow (relative) car on a slick, I tend to think the owner does not know how to set up a suspension. I went mid 11's with a 1.5 60 foot on a 275 M/T dr.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
Quote:
Originally Posted by Sidewayz6.0 View Post
I'd **** OPRAH!!!!!!!!
JD1969 is offline   Reply With Quote
Old 07-02-2009, 07:50 AM   #9
Kmelfi11
2002 Ford Mustang
Quote:
i had 17x8 in the front and 17x10.5 with nitto dr on them with that run, and it was at atco nj.
this is a pic from that day
__________________
Old 07-02-2009, 09:47 AM   #10
AmericanSpeed
2005 Ford Mustang
What tires/wheels are you running on the front? Running radials on the front with a bias ply on the rear will give you more of the "floating" feeling on the big end due to the difference in how the tires react.
A good DR will give you enough grip to max your 60' with the power level you are at now, though a slick will allow you more wiggle room to accomplish that same 60'.
__________________
05 Redfire GT: WHIPPLE HO @ 10psi, VMP dyno tune & other goodies - stock block, stock exhaust, stock 3.55s
11.324 @ 121.84 w/ 1.627
http://www.youtube.com/watch?v=dlBxdF5IqFM
11.36 @ 122.72 w/ 1.663
http://www.youtube.com/watch?v=BoGf6DiMVk4
Previous runs:
CAI+tune only 12.877 @ 106.79 w/ 1.819
CAI+tune+suspension 12.783 @ 108.05 w/ 1.841
both on stock tires
Please do not link companies in your sig
AmericanSpeed is offline   Reply With Quote
02, 2006, drag, ford, hoosier, mickey, mustang, pro, quick, radial, radials, slick, slicks, thompson, time, versus
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
