Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Went to the track, and got some questions?
Old 07-03-2009, 03:26 PM
67mustang302
67mustang302's Avatar
Headwind probably didn't help for sure. The weather conditions were practically identical, so that's not a major factor. Could be things like heat soak, how quickly you were shifting(some days you're slower than other days) etc etc. Could even be things like fuel quality that effect it as well.
67mustang302 is offline
Old 07-04-2009, 09:57 AM
buster
buster's Avatar
timing lights could be off, track prep, 20 mph headwind would make a difference, air, humidity......blah, blah, blah. Many different variables. You have to race the track that you are at.
buster is offline
Old 07-05-2009, 01:41 AM
Gene K
Gene K's Avatar
1. I lose 2 mph in a 16 mph headwind but Im 10 mph slower so that might effect you more.
2. One track I frequent is slightly down hill to the 1/8 and up until the 1/4. Its within NHRA/IHRA tolerence but it slows my 1/4 mi 1.0 mph compared to a flat track. My ET is the same for both tracks.
3. Was the speed the same in both lanes? Someone may have hit the light and it might have been a little off when they put it back.
4. Is Sacramento run to modern NHRA standards? If not it may have the old speed traps where they had two lights, one before and one after to get speed at the finish line. NHRA moved to using the light before and the finish line to try and keep the speed of Top Fuelers below 300 mph. The old arrangement was 2 mph faster.
Gene K is offline
Old 07-06-2009, 09:25 AM
aode08
aode08's Avatar
What was the temperature the old day and this day?
That itself can make a difference
aode08 is offline
10-07-2015 07:02 PM
mungodrums
10-07-2015 04:01 AM
heslekrants
09-23-2015 04:02 PM
09-08-2015 11:50 AM
whatsup62
09-03-2015 01:38 PM
Quick Reply: Went to the track, and got some questions?
