Go Back   MustangForums.com > Speed Zone > Street/Strip
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-06-2009, 02:40 AM   #1
Mishri
2007 Ford Mustang
Mishri's Avatar
Vehicle: 2007 Mustang GT
Default M&H drag radials.. disapointing results
Mods are in the sig, on stock tires I ran a best of 13.5@102mph DA of 4200 ft corrected down to a 12.8@108mph. 2.0 60ft
switched to M&H Drag Radials 275 on 17" stock rims.
1st run 2.43 60ft 14.198@100.67 DA of 5590 = 13.2@108mph
2nd run 2.27 60ft 14.07@99.94 DA of 5396 = 13.1@107
3rd run 2.34 60ft 14.150@99.75 DA of 5298 = 13.2@106
1st run I didn't do a very good burn out.. 2nd run was a bit better but didn't hold it for long, 3rd run i just drove through the water box, did a good burnout, but didn't roll it out prpoerly..
Place was packed.. funny cars + jet engine car and jr dragsters and big cash gambler ($2000) left little time for Time Only runs.. International Mustang Meet was there and club members got in for $25 instead of the $35 atleast..
I could have gotten one more run in but i was tired and annoyed.. a friend who goes a lot recommended I try leaving off idle.. another friend said it was because the tires are 1" taller..
Thoughts? opinions? I think i do need more practice burning out.. wish I could have gotten like 7 or 8 passes in and it was cooler.. it felt like i hooked really well on the 3rd run but apparently not.. although the guy saying i should leave off idle said sometimes cars act funny like he has a 4,000 stall in his but he leaves on 2,000 because it runs slower when he leaves any higher he hooks fine, it just doesn't run as fast.. I was launching at 2,000 rpm then dropped down to 1500 rpm for the last run. I was leaving off idle on my stock tires.
__________________
Auto, Steeda CAI & Brenspeed Tune, UDPs, CMDPs, 4.10 Gears, Boomtubes, BMR LCAs
285rwhp 304rwtq 13.5@102mph, DA corrected 12.7@108mph, Elevation corrected 12.9@107mph
Mishri is offline   Reply With Quote
Old 09-06-2009, 02:50 AM   #2
Red Turbo Integra
1994 Acura Integra
Vehicle: 1994 integra RS.
Try a better burnout. What's your tire pressure? I feel you on being frustrated. I can't get more than a couple of passes in when I go to the track. Doesn't give you a whole lot of time to practice which sucks. I'm still trying to find the sweet spot for my launch and tire pressure, although I know my DR are to small for my power level. I'll probably buy some different ones within the next month or so.
__________________
Extensively Modified Integra. Made in Japan, PERFECTED in America!
Quote:
Originally Posted by bluebeastsrt View Post
Way to go SPEED RACER. Rev to get a race and then not only do you get outlaunched but you start missing gears.
Red Turbo Integra is offline   Reply With Quote
Old 09-06-2009, 02:53 AM   #3
Mishri
2007 Ford Mustang
Mishri's Avatar
i took them down to 20psi.. someone recommended taking them to 17psi.. but i didn't want to drive them back (30 mile drive plus about a mile on really rough dirt road) that low.
__________________
Old 09-06-2009, 03:35 AM   #4
bluebeastsrt
2004 Dodge SRT-4
bluebeastsrt's Avatar
Vehicle: 2004 Stage 3 SRT-4
Location: usally a state of confusion. But I live in jersey
I'd try 17PSI but I'd take them all the way down to 15. I wouldn't go any lower than 15 for safety reasons!!!! Get a real good second gear burnout and launch at 4 grand. Also buy yourself one of those cheap compresors that plug into your cigarette lighter and take it with you to the track. It'll make tire pressure changes a lot easier and you can air your tires back up before you leave the track. I included a link to a decent Drag radial write up from a few of the top tire brands engineers.
http://www.superchevy.com/tech/0302S...als/index.html
__________________
11.79@118.53
BEST 60=1.68
BEST TRAP SPEED=120.60
I've never actually raced but according to my dyno numbers. I should run 8s on street tires.
Last edited by bluebeastsrt; 09-07-2009 at 06:17 PM. Reason: I'm stupid and can spell.
bluebeastsrt is offline   Reply With Quote
Old 09-06-2009, 04:01 AM   #5
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
DA sure wasn't helping. But i dont think your spinning on 11.5" wide drag radial's as long as you smoke them just a bit.
What about the burnout is throwing you off? Dont need a smoke show, just spin them in second for about 3 seconds is all you should need. Thats what i do and im leaving at 4000-4500rpm and dumping the clutch on 9.5" wide MT et streets.
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is online now   Reply With Quote
Old 09-06-2009, 11:56 AM   #6
Mishri
2007 Ford Mustang
Mishri's Avatar
I was told with the M&Hs you need a long burnout.. i did a 1 sec burnout the first time, 3 sec the 2nd time and like 6 secs the 3rd time.. so maybe the 3 sec is the right number.. it seemed like it didnt peel out to bad the 2nd or 3rd time.. just felt like it had no power..
__________________
Old 09-06-2009, 12:05 PM   #7
Big50
Vehicle: 2005 Ford Mustang GT
Quote:
1st, air them down to 17 psi or so. 20 is two high. Then when you do your burn out let it get to around 50 mph and once you see white smoke let them roast for about 2-3 seconds. With my mt's i found they needed to be broken in a bit before they really started hooking.
__________________
2005 GT, 5spd manual
Saleen S/C, 3.4 pulley, FRPP shorty headers, FRPP handling pack, uca/lca, pandhard bar,FRPP 4.10's. Performance by TPS MOTORSPORTS. 442WHP/435WTQ
12.10@111.7 1.64 60'
Big50 is offline   Reply With Quote
Old 09-06-2009, 12:40 PM   #8
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Vehicle: 4000 - 0 -.5 Yes, thats right. I tied half a race.
Send a message via AIM to JD1969
Any new drag tire is going to need a few good, hard burnouts at first. There is a bunch of slick crap on new tires. On a 275/17 tire I have pulled low 1.5 60 foots. I ran them at 17 psi, this seemed to work best. On a wider tire, with a low profile like these, lower psi will cause the tire to cup. You will have to try different PSI's to find what works best for this tire on this car, but be careful going too low.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
Quote:
Originally Posted by Sidewayz6.0 View Post
I'd **** OPRAH!!!!!!!!
JD1969 is offline   Reply With Quote
Old 09-06-2009, 04:51 PM   #9
TommyV8
2002 Chevrolet Camaro
TommyV8's Avatar
Vehicle: 2002 Chevrolet Camaro Z28
I leave my drag radials at the same pressure as they're driven around on (30 psi) and they hook fine like that.
__________________
2002 Camaro Z28 Mulletmobile
Automatic, 3.42 gears, stock converter
Airbox lid, full exhaust, drag radials
12.76 @ 109.76, 1.92 60 ft
TommyV8 is offline   Reply With Quote
Old 09-06-2009, 06:04 PM   #10
Stone629
2009 Ford Mustang
My Garage
Stone629's Avatar
Vehicle: 2009, Ford, GT/CS
You need to wear those tires down some, get that new film or whatever it is off of them, then they will hook right.
__________________
2009 GT/CS, Vapor Silver, Manual '
308.4 RWHP/317.4 RWTQ
13.18 at 107 mph (2.0 60')...(1,243' DA, 75 degrees)
8.58 1/8th at 85 mph
2003 Mach 1, DSG, Manual
O/RX, Flowmaster Cat-back, weld-in subframes, KN Filter
13.1 at 107.97 Mph
Quote:
Originally Posted by SubTexel View Post
And when I win, I club a baby seal in front of the loser to let him know that it's his fault the baby seal died because he lost.
Stone629 is offline   Reply With Quote
burn, drag, early, hold, integra, long, mh, mt, mustang, oil, radial, radials, review, street, tires
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
