and watch out for those sti's... AWD launches and big power when boost controlled.
my buddy has a silver one pushing 24#'s on the stock turbo (max limit) and that thing pulls like a freight train... im sure thats how a vorteched mustang pulls as well though
you'll hit your 12's at the track.. are you going with the njstanger guys? i think im sitting it out. i went last week. if you dont like the way your supercharger performs, you can always give it to me
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
and btw change your sig where it says chrome cobra r's and lightning mas
your wheels are 03/04 cobra wheels...
and its an MAF
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
i actually had it saying maf but then i thought it wasnt the filter but the sensor so i changed it to mas and the wheels i thought were cobra r's because my old ones where and they almost look exactly the same.
__________________ 02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
Vehicle: 07 Shelby GT #4487 of 5632 Performance White/Silver
Quote:
Originally Posted by mustang51js
yup on hamburg turnpike, do you go to the 7-11 in wanaque-haskell, thats where i saw a car like yours.
actually i dont think ive been to that 7-11 so its gotta be another guy..... hpwrestler is right..... although boost controlled at 24 psi is pretty much death for that stock turbo haha...... my sti made 334whp 376wt at 20 psi stock turbo... i should have been in the high 12's.... but my sti was abit from just stg2 haha im sure your vortech is right there with that. i actually have a vortech v3 kit that needs to be installed soon
__________________
07 Shelby GT # 4,487 of 5,632... 1 of 1,768 Performance White/Vapor 5MT
Vortech V3 SI trim @ 8 psi, SCT X3 w Brenspeed 93 tune, 39lb inject, KB BAP, BMR LCA/UCA, Hurst STS, 3:55's.... around 420whp 380wt...
12.90 @ 111.48 mph so far...
