Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
bad day at track, help
Old 04-08-2010, 08:21 PM
Stkjock
Retired Mod
Stkjock's Avatar
you need some supporting mods to take advantage of the added power
Stkjock is offline
Old 04-09-2010, 08:23 AM
HaV
HaV's Avatar
You have the trap speed for low 13's if you really hook up, but your launch is terrible.
The only thing you are likely to break if you launch that high is the stock clutch, which wont last much longer anyways. It will probably start to slip after a few good hard launches so be ready for that.
How much boost are you pushing? You should be able to leave the hole around 4k or so with those MT's with no problem. Your stock suspension should cooperate well enough to at least be dropping you down into the low 13's - I mean its not like you a stiffened ride and lowering springs all around, so it should hook up better than what your slip is showing.
I would say practice your launching and your times will get much better - and save your spare cash for a new clutch. Launching a supercharged motor on a stock clutch will wear it out pretty quickly. Dont start throwing random suspension parts at it till you learn how to launch it pretty well as is - They may help a little but you have to really learn to drive the car before you'll benefit from them.
HaV is offline
Old 04-09-2010, 09:21 AM
AmericanSpeed
AmericanSpeed's Avatar
How high are you revving the motor before shifts? You are trapping pretty low, maybe you are short shifting and not allowing that centri to really make some boost and power?
AmericanSpeed is offline
Old 04-09-2010, 04:45 PM
sjones1088
sjones1088's Avatar
i take it all the way to red line before shifting. and like i previously stated, im not spinning at all on take off, after i launch my car bogs all the way down to like 2k, maybe its just doing this cause of the stock gears? im not used to that cause on street tires im just spinning so my rpms dont drop like that
sjones1088 is offline
Old 04-09-2010, 07:08 PM
HaV
HaV's Avatar
You should feel some tire slippage with your powerlevel regardless of what tires you are running. What that means is your tires are grabbing when you drop the clutch and bogging everything down, or you have a tuning issue. My advice is to rev it as high as you can get it with the least tire slippage (but there should be a little) and you will likely resolve the problem.
HaV is offline
Old 04-11-2010, 10:45 PM
BKAT
BKAT's Avatar
yeah it is tuned, and i did upgrade the injectors and pump and everything else that goes along with the vortech. although someone told me they saw white smoke come out of my tailpipes when i shifted, so maybe the tune is messed up. i was kinda scared to launch at a higher rpm since my whole suspension/axle/transmission and everything else is stock, didnt want to break anything. here is my timeslip though
r/t = .108
60' = 2.263
330 = 6.130
1/8 = 9.210 @ 79.47mph
1000= 11.850
1/4 = 14.042
mph = 103.47
you said you hooked up good.....but you didn't .... no other way to say it....a 2.2 60 foot with M/T DR is not good......should at least be at 1.9 or lower.....That alone will shave off up to a second if you get a 1.7......just gotta practice.....it will come in timee
BKAT is offline
Old 04-11-2010, 10:50 PM
Stone629
Stone629's Avatar
I agree with Bkat. That 60 is no good for your set-up.
Bogging isn't hooking, its just bogging. I still say get those RPMs up to 4500-5k RPM on the launch and do work.
Stone629 is offline
Old 04-13-2010, 05:05 AM
acarzt
acarzt's Avatar
slip that clutch
acarzt is offline
Old 04-13-2010, 10:21 PM
Sace
Sace's Avatar
Am i the only one who thinks his mph is really low regardless of his 60' time. What kinda horsepower did the car put down? if you have had it on a dyno?
Sace is offline
Old 04-14-2010, 12:10 AM
bolton3valve
Banned
bolton3valve's Avatar
i agree even with minimum suporting mods it should trap higher then 103 unless he is on 5lbs or less lol?
bolton3valve is offline
Quick Reply: bad day at track, help
