Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Celica GTS VS RX-8
Old 09-02-2005, 08:26 PM
Moparman87
Moparman87's Avatar
Default Celica GTS VS RX-8
Ok... so if you raced a celica 6-speed stick vs a RX-8 with 193 HP whats gonna win in a twisted road? I think it would be a drivers race... and if the RX-8 was one with 238 HP what would the outcome be then?
Moparman87 is offline
Old 09-02-2005, 09:20 PM
Guest
Guest
Posts: n/a
Default RE: Celica GTS VS RX-8
I dunno. GTS's will run 14.8s in the quarter with someone who knows how to properly manipulate that wonderful 6 speed shifter, that's about what the 238 hp RX8s supposedly run.
In the twisties I honestly have no idea... the Celica has it by 500 lbs, and is one of the better handling FWD vehicles on the market, but the weight distribution on the 8 is absolutely perfect.
GTS - 1.8L Inline four, 180 hp, 130 ft lbs, 2500 lb curb weight (with 6M)
RX8 - 2.6L twin rotary, 238 hp, 159 ft lbs, 3,029 lb curb weight (with 6M) - one more feature, it has a perfect 50/50 weight distribution.
Old 09-02-2005, 09:34 PM
David_K
David_K's Avatar
i think its a 1.3L rotor isnt it? if not thats one ****ty engine
David_K is offline
Old 09-02-2005, 09:35 PM
Guest
Guest
Posts: n/a
ORIGINAL: David_K
It's a 1.3, but it has twice as many combustion cycles as a regular piston engine, so technically it can be counted as a 2.6.
Old 09-02-2005, 09:37 PM
David_K
David_K's Avatar
ORIGINAL: 2000Si
ORIGINAL: David_K
no its a 654cc x2 engine makin it 1.3L
David_K is offline
Old 09-02-2005, 09:39 PM
Guest
Guest
Posts: n/a
ORIGINAL: David_K
ORIGINAL: 2000Si
ORIGINAL: David_K
No **** sherlock, but within that 1308 cc's there's TWO combustion cycles on the rotor giving TWICE the power per rotation. Hence it can be counted as TWO 1.3L engines spinning at the same time. Hence it being able to be called a 2.6L engine.
Geezus.
Old 09-02-2005, 09:55 PM
David_K
David_K's Avatar
here you go home boy
from mazda http://www.mazdausa.com/MusaWeb/disp...ehicleCode=RX8
apology accepted
David_K is offline
Old 09-02-2005, 10:30 PM
89IROCZ
89IROCZ's Avatar
I just thought I would share.... Engine displacement is measured using the bore and stroke...Engine cycle is measured by the amount of power strokes per cycle.. The engine in the mazda I believe is a renewed B13 that has two rotors and two plugs per rotor ( if this is based on the older B13) this I believe would fire twice per rotor rotation making it most similar to a 1/2 cycle.. Not to step on toes here just trying to explain
89IROCZ is offline
Old 09-02-2005, 10:32 PM
89IROCZ
89IROCZ's Avatar
Oh and BTW 1300 cc's = 1.3 litres
89IROCZ is offline
Old 09-02-2005, 10:58 PM
Moparman87
Moparman87's Avatar
So the celica would kill the 193 HP RX-8 Model and it would be a drivers race for the 238 HP RX-8 ??? What about straight away.. or from a roll like say 35 mph up... Some RX8 is talkin chit around here..
Quick Reply: Celica GTS VS RX-8
