99 thru 04 gts, whats your 60 ft times
#21
How long do you expect those stamped stock suspension parts and rubber bushings to hold up to 1.5 launches though? And how much ET is being left on the table from running stock suspension and slicks? I don't think that the suspension necessarily needs to be re worked from front to back, but at minimum I would want LCAs, UCAs, poly bushings, torque arm, subframe connectors, and (depending on the car) weld-in torque boxes. Thats if if I were going to be pulling 1.5s every other weekend.
#22
Who knows....obviously the stock suspension wont handle 1.5 60 foots every weekend so if you race the car that much, upgrading parts is a must but thats not really the point...I was just saying you can probably see the same 60 foots on stock suspension with a real set of slicks vs spending thousands of dollars on lcas, ucas, lake wood shocks/struts, drag springs.
All I have is the MM extreme LCAs which have spherical bushings and ive had no problems.
Again, just comes down to the goal for the car.
I dont think the avg. mustang owner races their car every weekend.
I would be lucky if I got to the track more than once a year.
#24
#26
no doubt it wouldn't hold up, but imo a set of good u/l control arms, subframes, and torque box reinforcements and you're set. I never see anyone with drag setups including a torque arm, those are expensive and from everythign i've seen only help with turns, not launching. Also agree that while the stock suspension is capable of 1.5/1.6 60' times, you could still do much better with some actual suspension work.
#27
Not sure where you getting your prices.
hell, add up the cost for springs, shocks/struts, CC plates, install and alignment and your talking 1,000m maybe more easily.
the Extreme duty MM control arms that I have are 350 dollars alone, not including installation
Add up the cost to do drag coil overs, upper lower control arms, subframes, easily spend 2k
#28
#30
Lol, start adding it up...that stuff is not cheap, especially if your not installing the parts your self.
