TBSS vs. 370Z
Yikes! on a 4l70e? Isn't that a bit risky, to manually push it up to the next gear at WOT? I see it made a good difference,though.
What's even worse is that 2nd and 4th are on the same servo, so if you lose one you usually lose both gears.
There was also a write up about some other reasons you should always run in 3rd instead of 4th. Had to do with the way the fluid was routed or something. I'll dig it up later, but it's pretty much been proven that the TBSS will run the 1/4 quicker that way...it's an interesting read at any rate.
I hear you, I haven't stopped working on the fox. These couple mods on the TBSS are a win/win situation, I can gain about 30whp or so while gain a couple MPGs and only costing about $300 since the tune and programmer will be free.
I know how you feel. I've been kicking around the idea of a few mod's on my daily driver.
pretty much the same thing as your TBSS.
it's a 1995 buick roadmaster wagon. Chevy LT1 350ci motor, auto trans, 4500lb's I make less power, but still basically same ****. big vehicle, big motor.
wanna put a turbo on it SO bad and just troll people.
That's a nice DD. I wouldn't go as far as adding boost to it but maybe a mild h/c setup would really wake that wagon up.
