At track...
#31
#32
I took a trans class in college and am michigan certified, however there really isn't that much experiance needed. in class we used gm trannies and one of the ones i picked was the 4l60. pretty simple for a newer trans and if you were to take your time you could rebuild it yourself. I dont know what all you'll need to upgrade other than i know the sunshell in those is garbage. a beast sunshell, good clutch packs, upgraded o/d band, and some valvebody upgrades would make a world of difference i'm sure. if you do it yourself the big thing is get a big work bench and when you pull parts out lay them in order, the most complicated thing is getting it all back together where it needs to be.
#33
to be honest i think anyone with a general car knowledge could. if you bought a rebuild manual and took your time and was nice and neat i'm sure anyone who could do a complete tune up could rebuild their trans. it's just gathering up the courage to tear it apart, once you pull it apart all the little parts can be discouraging lol.
#34
#35
And it's not like it's easy for an average joe to go figure out. I followed that thread and I was completely lost
#36
****ty about the tran's.
time to baby it until you can figure out what your going to do.
I vote for the 800+hp trans...... why build it twice?
btw, did you weigh your car today? did you take out the passenger seat or anything?
#37
Didn't weigh it. I ran at full weight with about a 1/4 tank. Kind of wish I had of pulled the passenger seat and sway bar.
#38
that wasn't my reason for asking....
http://denver.craigslist.org/pts/2807826608.html
if you run that quick at 3700lbs or so race weight.......
imagine 3150 raceweight
#39
Grats on the new best!! My 4L60E started doing that and I tried to ignore it... Then it puked fluid all over the engine and left me stranded passing a car on the highway. I say time for an M6 swap. :P
Stall alone may put you on the edge of 11s especially if you're slipping on the 2-3 shift. Damn impressive times for so little done. At this point I would say the stock stall is holding you back on that launch and the trans is hurting you more than you realize. When my third went I lost all of the gears. When they pulled everything 3rd was a bare metal ring and 1 & 2 were 99% gone but still grabbing enough to move the car with out me knowing they were slipping.
Last edited by S8ER01Z; 01-30-2012 at 10:36 AM. Reason: iPhone + medicine = bad poasting
#40
I saw time for an M6 swap. :P
How complicated was that T-56 swap?
I know man, its getting a good stall with the built trans. I would be surprised if it didnt run high 11s with that and a good stout trans.
