Should I install longer wheel studs?
I'm going to be hitting the strip a few times a year, not a regular thing. I have my slicks all set, only needed a 1/8 spacer for the jeg wheels on the rear. No caliper grinding needed at all..
My fronts are Summits 15X4 with 1-3/4BS , PN: SUM-541-5465PS and a 1/2 Spacer with Slight caliper grinding. I was told that a 3/8" Spacer would need no caliper grinding but found that not to be the case. I'm not sure how much grinding there needs to be with a 3/8 space. But it seemed too much in my eyes. I may be wrong.
Anyway, I have both spacers, the 3/8 and the 1/2 inch but the 1/2 inch spacers is what I plan to use on the track only. Not going to use that on the street. I have 9 1/2 turns of thread engagement with the 1/2 spacer. Which comes to just under 1/2 inch, about 7/16 from what I can tell.
Now should I install longer studs or is this okay for the strip? I only plan on using this rim at the strip, no street duty at all.
http://www.summitracing.com/parts/cr...4/media/images
I also want to be able to use my current lug nuts, I know the extended lug's require you to use open end lug nuts. That's fine for the track but I'm only going to see the track a few times a year.
American muscle have these studs. I bought them for the rears and fronts. I wanted them to be longer bc putting the racestar wheels on can be a pita.
http://www.americanmuscle.com/arp-fr...tuds-0513.html
