Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
What am I messing up on during my launch? (video included)
Old 02-08-2013, 10:51 AM
UofHmustang
UofHmustang's Avatar
The highest I've tried to launch is 4k. Another 1000 should be getting there. I'm thinking about a two step but I don't know how hard it is on the motor.
UofHmustang is offline
Old 02-08-2013, 10:55 AM
TRexGAWD
TRexGAWD's Avatar
Two steps aren't bad if you just wanna floor it and go.. Should be fine on the motor as it's only revving to the stopping point you set it to (i.e. 5K rpms) so it's no different then just holding the throttle at that point yourself.. Keep in mind though if you plan to race it often and compete is certain events that two steps are not always allowed so check with your track regulations.
TRexGAWD is offline
Old 02-08-2013, 11:37 AM
UofHmustang
Good tip.
Old 02-08-2013, 01:17 PM
bluebeastsrt
bluebeastsrt's Avatar
Originally Posted by UofHmustang
So the PSI isn't to blame? I have no problems launching at 5k. I'm not expert but I'm quite confident I'm losing at least a half a second at the line that's keeping me from 11's. Those are some really sticky tires. I was fooling around with them aired up to 26 psi and they still stuck pretty good. They actually ride quite nice on the highway.
With those tires you'll most likely cut low 1.7 sixtys on average. Some high 1.6s. Control arms are a good investment if you plan on drag racing alot.
bluebeastsrt is offline
Old 02-08-2013, 09:27 PM
Stone629
Stone629's Avatar
You stock other than tires?
IMO, you shouldn't have to go all the way up to 5k to get a strong launch. I'm pulling 1.6 60s leaving at 2800 RPM. Here's my advice. First, put some air in those tires. 17 psi is way too low. You are creating a lot of drag with that low PSI. I'd take it up to at least 22 pounds, launch at 3500-4k slipping the clutch, NOT straight dumping it, and go from there. If it still bogs, then raise your RPM to 4200-4500 whilst slipping the clutch. I think its a combo of low PSI and dumping the clutch. Thats why you're able to half way launch without bogging at 5k RPM. Also, warm those tires up more. Get them smoking. Just takes practice, you'll figure it out.
Stone629 is offline
Old 02-08-2013, 10:20 PM
GT500Steve
GT500Steve's Avatar
What size tires are those and what gear is in your car??
If you are on a 28" tall tire and have anything less than a 3.73 or 4.10 (preferably), there is your problem. You will have to rev it to the moon to keep it from bogging.
A litle bit of clutch slip is a good thing also. If you hit it too hard (5K clutch dump) the stock 2 pc driveshaft may let go.
GT500Steve is offline
Old 02-09-2013, 08:11 PM
outceltj
outceltj's Avatar
Maybe a bit more time in the box. It sounded like your spinning
outceltj is offline
Old 02-09-2013, 08:27 PM
UofHmustang
I have the stock 3.31 rear gear. They're 275/60/15 but I don't know how many inches that translates into.
I don't really dump it when I go. It's more like I jerk my knee and foot up at the same time.
Old 02-09-2013, 08:30 PM
UofHmustang
You're about the 3rd person to tell me the MT ET Street radials should be aired up higher than what they recommend on their site. I'm definitely going to start out at 22 psi when I try again.
Car has LT headers, off road x-pipe, and Bama 93R tune.
Old 02-09-2013, 09:11 PM
code3GT
Mustang Nazi
code3GT's Avatar
Yep....raise the rpm's....launch that sucker
code3GT is offline
Quick Reply: What am I messing up on during my launch? (video included)
