Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Traction issues at strip!!
Old 07-23-2013, 08:36 AM
Stone629
Stone629's Avatar
You might need taller tires. I'd try 28s and go from there.
Stone629 is offline
Old 07-23-2013, 07:30 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by jeff37110
Upr chromoly k member kit,coilover spring rate 12in 250rate,extreme bumpsteer kit for the front with strange 10 ways..17x4.5 darkstars with m&h tires..
Rear
Upr upper and lower controls arms..
Upr full length subframe connectors with seat brace
Stock gt spring with coil cut..
Lakewood 50/50 shocks..
15x10 darkstars with brand new mt 26x11.50 15 et streets..
Which upper & Lower control arms?
That suspension setup should work well. The rear tires are small and the front springs are stiffer than I'd prefer, but still, unless you're making crazy power, it should hook hard.
UPRSharad is offline
Old 07-23-2013, 10:11 PM
jeff37110
jeff37110's Avatar
Im running the fixed length upr control arms,but have the double adjustables on the way..Maybe its in my pinion angle,but I just dont see it making that much difference..On the spring rate, I did have 12inch 175rate springs and my car would bottom out on the street..Went with the 250 spring and it fixed my ride problem..
jeff37110 is offline
Old 07-23-2013, 10:12 PM
jeff37110
jeff37110's Avatar
What spring rate would perform better at the dragstrip for me and still be good street spring??
Old 07-23-2013, 10:16 PM
jeff37110
jeff37110's Avatar
Im thinking same thing,to bad I just bought those et streets...Maybe I can sell them to a buddy or something..Only thing Im afraid of is a 28 inch tire might hurt my gear ratio,but guess its worth it for traction....I see in your sig you ran 7.4 @92..Im spinning so bad Im running 7.8 @95 mph..I have great mph so there should be no reason not to run low 7's..
Old 07-23-2013, 11:42 PM
BairdGT
BairdGT's Avatar
What kind of ETs and 60' are you posting on average with your runs?
I would agree no reason for you to not be posting mid 7's with your setup
BairdGT is offline
Old 07-24-2013, 06:04 AM
jeff37110
jeff37110's Avatar
I went 1.79 60 ft and 7.77 1/8th 94.8 mph with et street radial 275/50 15..
Best 1.89 60 ft and 7.85 1/8th mile 95.1 mph with et street 26x11.50 15..
Im averaging somewhere from 7.8's to 8.0's in 1/8th mile..My 1st gear is almost useless..
Old 07-24-2013, 06:34 PM
Stone629
Stone629's Avatar
Yea, 28s will hurt your ratio. Might cost you up top too, just depends on how bad you need the extra gearing. There's a calculator somewhere that will configure your ratio for you.
You should be able to run some low 7s. Just gotta figure out where the problem is. Maybe need to adjust your launch RPM/Clutch engagement, could just be a bad track/prep...really hard to say. Be cool if you could borrow some 28s before actually buying a set to see where they put you.
Stone629 is offline
Old 07-24-2013, 06:54 PM
jeff37110
jeff37110's Avatar
My buddy has a set of 28s.. I may try that first..I was also told by few guys that the air was bad at track last weekend.. So I'm hoping it was bad track conditions..
Old 07-24-2013, 07:14 PM
Stone629
Stone629's Avatar
I would def borrow your friend's tires before buying another set. Those tires aren't cheap. You thinking about running again this weekend?
Stone629 is offline
Quick Reply: Traction issues at strip!!
