Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Comp Cams/ FRPP Intake Manifold - Worse 1/4mile Times?! Wth..
Old 08-21-2014, 03:14 PM
Mellowdien
Mellowdien's Avatar
@Explosive, unfortunately, we rented out the track and werent getting slips, we just looked at the screen after every pass. And out of frustration with the times i forgot to pay attention at the speeds...
car felt the same at every point so i think it wouldve been around the usual 168km/h
Mellowdien is offline
Old 08-25-2014, 11:51 AM
stealth_GT
stealth_GT's Avatar
Damn, no time slips?? that holds the key to everything. If your 60 fts. didn't budge your times won't change. Ditto on the shift points on shifting higher + the FRPP intake manifold to take advantage of that cam and higher flowing intake. You're running stock springs and retainers on a comp cam?
stealth_GT is offline
Old 08-25-2014, 09:27 PM
Mellowdien
Mellowdien's Avatar
@Stealth, yes it's an NSR cam, my 60ft times were worse than what i'm used to (stripped, skinnies and slicks), was usually around 1.9, best i could come up with that day was 2.0xx.
Even then, not much worse than what im used to. i was just expecting the car to pull harder at the top end. trying different tunes this weekend from Bama and a remote tune from Lund
Old 08-26-2014, 12:35 AM
stealth_GT
stealth_GT's Avatar
3500 stall and the best 60 ft. is 1.9?? I run a measly 2800 stall and I cut 1.9's on street tires and 4560+ lbs. My 2008 Mustang GT was cutting 2.0's on MT ET Streets on the stock converter and 4.10/auto.
I'd be more concerned about the 60 ft. than anything else. The tune can be figured out, I'd be more concerned why it's not cutting at least 1.8's or even better considering your stall and weight (roughly 3400?). I wouldn't expect it to pull any differently up top if your running the same shift points as before (6259?), I'd assume a 6500 shift point would be best with your new set up. I don't think it would even start to make power until past the shift points you have right now.
I used to run only Doug Bama's tunes and they worked amazing on my Mustang..
Old 08-26-2014, 02:03 AM
Mellowdien
Mellowdien's Avatar
@stealth, i understand the importance of the 60ft, you're also the 20th guy on here thats told me that. Our track is completely unprepped.
Here's a clip;
The Cobra Jet runs low tens (~10.1 - 10.4) 60ft is 1.8's
CBA GTR's here also, 1.8
This was pre cam and intake
My shift points are set at 6475RPM.
My point was before my intake and cams, i coulve also worked in my 60ft.
I want to make these parts work for me. I'll try to get more feedback from Bama to see what they think i should set my shift points at
Old 08-26-2014, 03:34 AM
stealth_GT
stealth_GT's Avatar
damn.. I assumed it was at least an IHRA track, but a track is a track.. I had no idea it was straight up concrete lol.. never seen that before. Rest assured if it had been a IHRA prepped track you should be running way better times. Start up tunes are rough anyways, sounds like it just needs to be dialed in.
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
Calizic
08-28-2015 01:46 PM
soulcaliber39
08-26-2015 03:26 PM
ding56
08-14-2015 02:40 AM
Quick Reply: Comp Cams/ FRPP Intake Manifold - Worse 1/4mile Times?! Wth..
