Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Track update after gears.
Old 03-05-2017, 10:32 PM
Stone629
Stone629's Avatar
I didn't really think it was possible. Especially with that trap. Still doesn't make me want to run out and buy one lol.
Stone629 is offline
Old 03-06-2017, 07:54 AM
88 orangepeel notch
88 orangepeel notch's Avatar
You spoiled southern guys,........ getting to race year round practically. Must be nice lol.
Congrats on your gears Stone. 12.4-12.5 with tires.
88 orangepeel notch is offline
Old 03-06-2017, 01:37 PM
Stone629
Stone629's Avatar
It's nice down here right now, Orange. Most of February has been in the 70s with several 80 degree days. Not all that normal honestly, but even a normal winter isn't enough to shut the track down for a whole month or anything.
Looks I'll be buying some better tires.
Stone629 is offline
Old 03-07-2017, 07:21 AM
Explosive
Moderator
Explosive's Avatar
Ugh, i need to move lol
Explosive is offline
Old 03-07-2017, 10:35 AM
Stone629
Stone629's Avatar
Originally Posted by MaxxRPM
Right.......If I could figure out had to shift the MT82 I might be able to lay down some Stone times..........
Looks like you're doing very well with the Mach. Are you going to keep it or go back to the LS?
Didn't mean not to respond to you. I'm going to hang on to it for awhile. LS is def an easier route, but I'm having more fun with this Mach. I'm racking my brain trying to figure out where to dig up $3-4K for a blower but yea. Zex has some fairly cheap wet kits, but I guess I better do the responsible thing and fix the traction first lol
Stone629 is offline
Old 03-08-2017, 03:29 PM
bluebeastsrt
bluebeastsrt's Avatar
Brother, throw a couple of adjustable dampers on the back and and air those tires down.
bluebeastsrt is offline
Old 03-08-2017, 08:07 PM
Stone629
Stone629's Avatar
Is that what it needs? I'll do it if this is the issue. I didn't take a pressure gauge, but I let some air out and when I did it dropped to a 1.99 60'. Your input is appreciated sir.
Stone629 is offline
Old 03-09-2017, 04:28 AM
bluebeastsrt
Ive found that a lot of people show up with to much air in their drag radials for the weather. I'll run my radials as low as 14 psi on a cold day. Never higher than 16 on a hot summer day. Never hurts to try. Lowering the air is free. A couple of cheap drag springs and a set of dampers set to soft. Helped my 95 a lot. Id bet with the gears, you could cut low 1.7s maybe even high 1.6s once you get everything ironed out.
Old 03-09-2017, 05:32 AM
Stone629
Stone629's Avatar
You're right about the tire pressure. I showed up full pressure. That 2V that ran low 13sdid too, but dropped his to 18psi and went from 2.1s to a 60 that put him on that 13.2. I'm going to order those shocks and springs anyway, I'll need them for sure later either way. That and lower the pressure. I know this car can do better than this.
Stone629 is offline
Old 03-09-2017, 07:42 AM
Explosive
Moderator
Explosive's Avatar
When i first started i aired way down a bogged but I'm an auto. You could try starting really low and if it hooks keep going up 2psi per run until you start spinning again. You dont want to go too low though. I didnt notice much difference if any with my adjustable shocks but i dont hit the tires like a stick car.
