Suspension Ask all of your general suspension questions here!
Anyone using a rear shock tower brace?
Old 05-19-2011, 10:44 PM
gnx547
gnx547's Avatar
Default Anyone using a rear shock tower brace?
Anyone here have a rear shock tower brace? For my 95, I bought the steeda rear shock tower brace and the brace won't sit flush and line up even on the shock tower. One side lines up flush but the other side won't line up flush..Seems like the bar is just a tad bit short..Has anyone had this problem installing a rear shock tower brace?
gnx547 is offline
Old 05-19-2011, 11:01 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I don't see this part doing you any real good on an SN95
Possibly on a Fox body and certainly not on the S197 either. If you don't already have FLSFC's, I would recommend those instead. They are a noticeable improvement and will help to reduce sagging of frame over time.
Jazzer
Jazzer The Cat is offline
Old 05-20-2011, 05:17 AM
Aereon
Aereon's Avatar
For a car that age, could be that the body has twisted a bit. the sn95's frames are pretty flimsy in stock form.
Shock tower braces haven't really been known to do a whole lot. I'd do what jazzer says and sell those to get a set of flsfc's.
Aereon is offline
Old 05-20-2011, 06:20 PM
gnx547
gnx547's Avatar
I already have the MM full length subframes.
gnx547 is offline
Old 05-25-2011, 11:59 AM
Norm Peterson
Norm Peterson's Avatar
I don't know much about the roof structure of a SN95, but assuming that it's good enough in the first place to let you benefit much from any shock mount brace, I'd start thinking about ditching the rear seat and fabbing up something more along the lines of the X-brace found in the new S197/Boss/Laguna Seca models. A thinnish tube tied straight across isn't going to accomplish much, since the loads that you'd like to stiffen against are not in the tube's stiffest direction (they're in what's probably the tube's least rigid direction).
Norm
Norm Peterson is offline
Old 06-17-2011, 08:10 AM
AdderMk2
Banned
AdderMk2's Avatar
a rear shock brace would do NO good in an SN-95. NONE what-so-ever.
The shock towers (for lack of better description) are almost completely non load bearing. There is no spring pressure there, and there is no axle attachment there. The area of the vehicle in question is not subjected to torsional stress.
AdderMk2 is offline
Old 09-09-2014, 12:19 PM
1998GTVERTT
1998GTVERTT's Avatar
Norm
has anyone done a laguna seca style brace? i really want one in my vert because i hate the vert bar....ugly.......and i think itd be unique, and im doing a 4v 5.4 swap so ill need some regidity
1998GTVERTT is offline
Old 10-18-2014, 06:06 PM
84CopperGT
84CopperGT's Avatar
I had one on my 04 vert. Didn't do ****....until I fabbed up an x brace for it using the tower bar to tie it in. then it was amazing.
84CopperGT is offline
guitarman376
10-11-2015 01:47 AM
67STANGX2
09-24-2015 12:29 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Anyone using a rear shock tower brace?
