Remove quad shock for autocross
If all goes well I am going to take my first shot at autocross on Friday. My suspension is all stock except the springs have one coil cut off each of them. Should I remove the quad shock? Eventually I am going to get better LCAs and ditch the quad shock but right now its still all stock. Also will it hurt anything to DD with the quad shock off or should I wait until I get LCAs before I DD with no quad shock?
Removing the quads may add a bit of rear-end "waggle", but not much. I recommend you run AX exactly as your car is now and for another 5~6 events prior to any additional suspension mods. Then, install some LCA's and remove the quads for another event or two.
Then go out and purchase a complete Griggs Racing GR-40 SLA equipped suspension with a WL and built Vortec induced '04 Cobra motor for your following events
..... what?
Jazzer
..... what?
Jazzer
Norm
Made it out to the autocross. It was a lot of fun. Definitely gonna need tires and suspension to keep doing it. I was having trouble with *** end stepping out a lot. When the Vortech goes in it will be impossible to keep straight. lol.
I recommend you hit AX up a few more times prior to any additional mods. Learn to keep the boost in check on your current set-up and will be a better (aka faster) driver in the end. Good tires and suspension mods can allow you to learn some bad habbits early on and help you to "get away" with stuff you probably shouldn't.
Jazzer
Jazzer
Agreed, and I wouldn't even get tires just yet. You might as well get the steepest part of the learning curve done on whatever tires you've already got.
One thought - it takes a finite amount of time to turn the steering wheel (I've heard up to half a second, which is about a car length in terms of distance). So for slaloms in particular you need to start your steering input before you get to each cone instead of when you're right at it. This takes a little practice before you can trust that you'll still go around each cone instead of running them all over.
Norm
Norm
The quad shock setup was added by FOMOCO at the specific request of the CHP (California Highway Patrol) due to hard cornering issues with only the dual shocks. The purpose was to prevent wheel hop during initial launch, but also to prevent wheel hop during acceleration at corner exit. I would leave them alone for autocross. That type of racing is basically what they were designed to help for.
