eibach sportlines for 99-04 v6??
Your car would not be quite as low as a V8 model, but Sportlines are indeed about the most aggressive drop out there for an aftermarket spring. This said, I happen to think that the drop is a bit too aggressive and can lead to some unwanted issues. Installing Sportlines on OEM shocks will give you a lousy handling/cornering ride, so you really should get some matched shocks/struts at the same time. If not, you can end up with a kidney-killer and sucks to drive
What are the ULTIMATE goals for your ride?
This question must be answered to mod ones car efficiently and end up with the car he/she ALWAYS wanted.
Jazzer
Jazzer
Jazzer
Jazzer
thanks. im looking for mostly style and a bit of performance, for shocks im probably going to get a konis or bilsteins. i know there are other brands out there but these are my only preferred.
Just be sure they are valved for the Sportlines to match them properly. I don't know the difference in weight between the GT and V6, but sure it will not be as low as the GT. I would expect it to not only be a bit less drop, but probably ride a bit rougher, as there is not as much weight to compress them.
Jazzer
Jazzer
Jazzer
Jazzer
as long as its low enough to be between moderate drop and slammed ill be satisfied.
the ride quality i dont mind im used really good and bad suspension.
thanks.
I can say I was that way when I slammed my '85 GT. I dumped it to the weeds and just wanted it to look good. Wasn't until many years later, I figured out that a proper set-up not only rides/handles much better, but can be just as low. It just takes $$$ to modify the suspension in a few specific ways to address it. My Saleen bottoms out on a match book... lol
Jazzer
Jazzer
On a V6 with Sportlines (or spring that drops as much as them), go with aftermarket fox body shocks/struts (I did Bilstein). It will greatly improve the handling b/c it will be matched better. I'd also suggest fox body A arms up front to correct the camber issues you'll be running into... otherwise you'll eat up a set of front tires once a month from negative camber. The fox A arms are slightly shorter, and will help pull the bottom of the wheel in a bit, correcting the massive amounts of neg camber from sitting so low. It will also help eliminate some of the stress you'll be putting on the front suspension.
ive been alot of phases as far as car goes(mostly canyon racing but street racing is nothing like the track obviously) i just wanna keep things simple, kinda tired of my cars falling apart lol.(had a toyota and civic back then)
ive been in a car that had koni yellows on full stiff, rides like crap(compared to a benz atleast) and in cars with horrible horrible suspension set ups. so i dont mind ride quality.
