Do i REALLY need CC plates?...
going to order the sportline springs from AM and match them with Tokico front and rear shocks/struts from Stangmods
can get the set for about $578 but with the Caster Camber Plates it would be around $775.
This will be the first car i have lowered with the correct spring shock match and am curious about the CC plates, droped my M3 with just springs and never had the plates.... show me the light guys
But basically you have a [front] tire munching monster when you do that.
When you lower a Mustang at all (yes, including 1.25" drops) you should install the cc-plates and have the car aligned. That will ensure proper handling and tire wear.
I think you're looking at this the wrong way though. It sounds like you're looking for reasons NOT to buy the cc-plates, when in reality you should be looking at all of the reasons you SHOULD buy the cc-plates. For example, regardless of ride height, your car has strut suspension, so sloppiness in the factory cc-plates can mess up the tow, caster, camber, and steering/handling in general. Upgrading the cc-plates improves the handling even at stock height because the struts (which are a major portion of the front suspension) are attached more precisely. (in the case of UPR Products CC plates, you upgrade from soft rubber strut mount bushings the car came with to solid spherical bearings with our plates) The difference in steering is huge!
Sharad is on the money here
CC plates not only allow you to get your car back in to alignment specs, but allow the addition of some caster as well. This is quite beneficial and particularly when one has installed wider wheels/tires up front. The OEM adjustment is minimal and why CC plates are of real benefit.
Jazzer don't run CC plates
Absolutely.
They also give you the freedom to set your cambers to a value that better suits your driving. Ford's range and preferred numbers are intended for the average driver, plus/minus some tolerance. Individually, there may well be a more advantageous setting.
Might be just a wee bit difficult on your car, no?
Norm
Norm
Yep. People often think of the CC plates as only helping to adjust the alignment, but good CC plates like UPR's dramatically improve the steering feel by replacing the crappy factory strut bushings with spherical bushings which are solid. So it's a win-win proposition.
