SuspensionAsk all of your general suspension questions here!
Welcome to Mustang Forums!
Welcome to Mustang Forums.
That is a very aggressive drop and really don't recommend it Issues of suspension geometry come into play and creates some funky issues without getting into more serious modifications.
What are the ULTIMATE goals for your ride?
Jazzer
Well, I guess 2" would be a bit extreme, maybe 1" 1/4. I just want it lowered to look good when I get my staggered set of 03 Cobra wheels. 315s in the back. I just want to know what would be recommended for a lowering kit. Not looking at coilovers btw.
You may want to purchase a kit that already includes springs and dampers. There are lots of them out there and will have parts matched to work well together. Be advised that there are some small issues that come into play with even a moddest drop. You will pick up some negative camber (top of front wheels tilted inward) and will create some un-even tire wear up front. This can be addressed, via CC plates, but they will add a bit of NVH (Noise Vibration Harshness) to your ride, so just be advised of this.
I can recommend you contact Sam Strano (Stranoparts.com) and/or Sharad (UPR Products.com). Either can work with you to be totally custom, or hit up AM or MM for some kits that are already matched together.
Hey, that setup looks awesome man and not too expensive. It's my daily driver as well so this would e perfect.
Thanks. It's was a nice setup. It cruised nice and smooth with the top down (date night mode) but when I was feeling froggy, I'd pull into a parking lot, stiffen up the shocks and struts (takes about two minutes with no tools), and go attack the corners.
You can give us a call at 561.588.6630 if you'd like to pick up the same setup. We do offer MF forum members a 10% discount on everything we manufacture, but since the dampeners are Strange Engineering and the springs are Eibach, the discount would apply to the cc-plates. I can throw in a t-shirt and some stickers though.
This forum is owned and operated by Internet Brands, Inc., a Delaware
corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford
Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor
Company
