suspension set up help
ok i have a 86 gt 5.0. this summer im wanting to replace my suspension. im pretty sure its all original and it rides horrible. i need your guys opinions on what to buy, i heard that the coil springs are really good and most likely don't need to be replaced and that being said im not wanting to replace them anyways i was thinking control arms, shocks, and struts. my car has 82,000 miles. i will mostly be running on the street as a DD but i wanna be able to go to the track like 4 times a year. what is the best set up for me? thanks guys
Sounds like you are a candidate for just a set of dampers all around and maybe some sub-frame connectors. For your described needs, this is about as far as I would go, but can certainly go farther. Doing so, will start giving you NVH (Noise Vibration Harshness), so you want to consider what else you want to install and why.
Jazzer
Jazzer
Matt's 95 Stang
10-05-2015 07:16 AM
