ball joints and struts.
I say thanks for your invaluable advice. However at this juncture I am forced to change my ultimate goal to stock and safe. I'm about to have to put new siding on my house. So that's going to get most of my attention. I did manage to get a k member from a u pull it place for $15 on Tuesday. They called it a large crossmember. I was also able to get the steering shaft that runs between the column and rack and pinion and the power distribution box cover and only spent $35 for all three parts. So I just need a stock strut and a few bushing and ball joints and ill be all good for my alignment.
Yes that is my direction at this time. I figure it will give me the opportunity to enjoy it as Ford intended and then later to really enjoy it as it should be. Though I do still question ball joints. I also still have an ABS/traction control issue to track down. But I am only a few parts away from having everything I need to repair my front end.
Yeah. Restore front end, get alignment, get new tires (all four match 245/45 17), new rotors and pads, fix ABS. My rotors are cross drilled and slotted and have stress cracks everywhere. Final bill will go to paint and body work. I figure a year on the stock suspension will give me a better idea what my limitations are with the vehicle are and what I want to do with it ultimately.
Last edited by phoenixfriend84; 04-30-2012 at 08:16 PM. Reason: 245/45-17 not 245/25-17
Sorry to hear about the stress cracks of your rotors, but sounds like you bought some cheapos Either that, or the rotors are not seeing "proper braking techniques"
I like your plan as it is best to find out what the car can do and what you can accomplish in spite of it That is to say, the pre-S197 chasis has some pretty major limitations to serious cornering, but ALL can be addressed with the all-mighty $$$ when it is time
Jazzer
Jazzer
Very possibly on those stress cracks. I bought it that way. I'm actually looking for some that are only slotted. Whether they are better than cross drilled or slotted and cross drilled isn't that important I like the look better. I was wondering what all is needed for the cobra brake swap. Calipers, rotors caliper brackets dust shields and go or is there more to it?
I have peeped your braking giude. what exactly is the difference between the two besides the rotor size? are the front calipers different or just the placement of the caliper? i can wait patiently until one comes to the local pull a part. or if its just the placement then ill just get the bracket and polish my calipers and have a look like no one else.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
