Suspension Ask all of your general suspension questions here!
note: GT500 strut mounts will not work with 2013 struts
Old 05-29-2012, 05:58 PM
Frustration
Frustration's Avatar
Default note: GT500 strut mounts will not work with 2013 struts
In case you're a 2013 owner and wanting an inexpesive drop using just springs (and not also replacing shocks and struts) and were going to use the GT500 strut mounts.
The stock struts on the 2013 have a much larger bolt at the top and it will not fit all the way into the GT500 strut mount that a lot of people use for adding lower springs to the front while keeping their stock struts...
The FRPP Struts do work in the GT500 mounts. The 2013 stock struts do not...
Frustration is offline
Old 05-29-2012, 07:54 PM
tj@steeda's Avatar
The Steeda HD mounts will work as well
http://www.steeda.com/store/steeda-2...ut-mounts.html
Best Regards,
TJ
tj@steeda is offline
Old 06-15-2012, 06:23 PM
Funster_2011V6
Funster_2011V6's Avatar
All you had to do was change the springs. A new strut top isn't needed. Lowering springs from 2005-2013 all are the same. V6 or v8 is the only difference cause the v8 is heavier.
The point of the GT500 strut mount is to make 2010 style FRPP struts fit.
Funster_2011V6 is offline
chrisdbassplayer
09-01-2015 05:30 PM
GimpyHSHS
08-29-2015 06:30 PM
inyadreems
08-21-2015 09:10 AM
cedarmn
08-20-2015 03:14 PM
01moostanggt
08-17-2015 01:22 PM
Quick Reply: note: GT500 strut mounts will not work with 2013 struts
