getting lowering springs, what else do i need?
tomorrow i am going in for eibach sportlines which is about 1.1 front 1.8 rear, no other suspension mods atm. will i need an adjustable panhard bar and will i need to align my car after the drop? what are some prices on alignment?
You would be advised to get an adjustable PHB, but is mostly for esthetic reasons. The axle will be moved off-center, but you might be a lucky one that is already off to the passenger side from the factory
I see the UPR double adjustable as good for your needs. If you were really hardcore into corners or track, I would recommend the brace or maybe a spherical ended PHB, but otherwise, this is purrrfect
Alignment..... no idea as to cost, as it is going to vary around the country. keep in mind, you probably wont be able to reach OEM specs after a drop. I am not too familiar with the S197, but "think" that the post '09 Stang might have a bit more CC adjustments in factory form. Typically, you cannot get enough adjustment to square up the wheels to OEM specs, so expect to have an additonal .75* of neg. camber after your drop.
Jazzer
Jazzer
ok, sounds decent, i called eibach and the rep recommended some cheap 20$ camber bolts they make as well as the adjustable phb.
could i expect any issues if i only get springs in terms of something breaking? also concerned about tire wear =/
I would not run "cheap" camber bolts
The ONLY bolts I would consider are those from FRPP. All of the aftermarket ones, of which I am aware, are not nearly as strong. You DON'T want a broken camber bolt and CC plates allow a wider range of adjustment with the addition of some caster.
Jazzer
Jazzer
Expect your cambers to go somewhere between 0.5° and 0.75° more negative than wherever they are now. Toe will probably shift a little, too.
When you're modifying your suspension, you should never be thinking with the word "cheap" at the front of your mind, nor that the fasteners that hold it all together are mere afterthoughts.
Norm
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
