Suspension Ask all of your general suspension questions here!
bought MM CC plates have a question
Old 09-18-2012, 04:28 AM
01MGGT
01MGGT's Avatar
Default bought MM CC plates have a question
It says I can put them in a negative or positive orientation. which should I do? I know this changes the max negative or positive camber you can run. How much camber should I be running on a car that will see daily driving but will also see a good bit of twisty mountain roads when I want to have fun? I am thinking -1.5 may be a good point to get a little better front end grip without hurting tire wear much?
01MGGT is offline
Old 09-18-2012, 09:46 AM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
I put mine on negative orentaion as I drive my everyday and thats what the directions say to do for DD cars but thats just me. So far about 500 miles on them and no problem just make sure to get a good alignment so you dont rub like I did for a while.
Matthew
Matt's 95 Stang is offline
Old 09-18-2012, 11:20 PM
1slow67
ROTM Moderator
1slow67's Avatar
Stock is -1.3
1slow67 is offline
Old 09-20-2012, 12:11 PM
01MGGT
01MGGT's Avatar
thanks guys. I thought stock was like .05 or some really conservative number. Any advice if I plan on spirited driving? I am thinking -1.8 or so should help handling a little. But not sure and also not sure which orientation would be best for this. Perhaps I should call MM
This is on a 95 GT btw
01MGGT is offline
drfister
05-03-2018 10:38 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
tmdm
08-07-2015 10:24 PM
Quick Reply: bought MM CC plates have a question
