Rear Support Brace is rotted - MustangForums.com
Suspension Ask all of your general suspension questions here!
Old 09-21-2012, 01:15 AM   #1
StrongStang
Default Rear Support Brace is rotted
I was doing an under carriage inspection & noticed my right side rear support brace is so rusted I can stick my finger straight through the middle of it. I went to the Ford stealer & they want $1,200 for a set of 2.
Part #'s 76102-B/54 & 55... They're insane!
So I've been researching some solutions & would like your feedback & advice. Btw in the Haynes manual it states that these braces are only found on convertibles .
Solution 1: Junkyard. Cannot find a convertible mustang anywhere so that's out.
Solution 2: Get this or something similar to this BMR subframe connector & have it welded on... http://www.summitracing.com/parts/BMR-SFC011R/
Solution 3: Remove both braces & take them to a machine shop for repair and/or reinforcement
Can you guys give me a DIY tip or solution? If not, maybe someone on here knows of a good shop in the NYC area that has experience with chassis modding & reinforcing
Thanks in advance
2006 Mustang V6 Convertible
StrongStang is offline   Reply With Quote
Old 10-07-2013, 07:46 PM   #2
cessna
Default rusted brace
Did you fix your rusted braces and if so how. I have the same problem. One would think there would be a call back on these.
cessna is offline   Reply With Quote
Old 10-11-2013, 12:47 AM   #3
StrongStang
Nope. I had many other projects to tend to since then but it's still on my hit list... Have you searched around for any solutions??
Old 05-26-2014, 10:16 PM   #4
don-ohio
Same here............rusted. Need new ones.Keep in touch. I just joined here.Thanks! don-ohio (:^)
don-ohio is offline   Reply With Quote
Old 06-04-2015, 09:10 AM   #5
rooneyeb
Hi, I was underneath my 07 fixing a loose clamp and found the same issue - the passenger side is perfectly fine and the driver's side brace is rotted... It appears not only was this simple piece of metal over $500, it now lists on websites as not available/discontinued. I may check a metal shop to see if they can weld something to it, or refab. But first I wanted to see if since this last post if anyone had any other simple/cheaper solutions. Thanks everyone - ejb
rooneyeb is offline   Reply With Quote
Old 08-11-2015, 07:39 PM   #6
HaefDog
Smile solution to the convertibe rear brace
Here is what I found:
AR3Z-76102B55-B Left through 8/09 500 dollars more or less
AR3Z-76102B54-B Right through 8/09 500 dollars more or less
AR3Z-76102B55-A Left after 8/09 240 dollars more or less
AR3Z-76102B54-A Right after 8/09 240 dollars more or less
My 2006 had the right side rusted very badly and fell apart when I removed it from the vehicle. The newer braces will fit the older mustang. the newer brace has an extra bracket for 2 additional holes that can be left alone or easily drilled and two additional bolts added. The torque for the bolts are 46 ft lb on the bigger bolts and 18 ft lb on the one small vertical bracket.
I found both the braces from a 2014 donor convertible and they are a direct bolt in replacement for my 2006. Ford is specific in the tightening sequence and recommends that both removed and installed at the same time. All bolts are to be stared by and, the front two are tightened, the rear two, then the front /center bolt and then the small upper one last.
I suspect most salvage yards dont have a big call for these pesky braces as they are in the way when they remove the rear diff from a donor car. My spot put them in the car body and I was able to purchase them for 25 for the pair. A great deal I thought they looked near new and only had minor scrapes which painted very well.
Now my 2006 is sporting Ford factory braces, albeit from a 2014.
HaefDog is offline   Reply With Quote
Old 08-11-2015, 08:38 PM   #7
HaefDog
I mis-spoke, it was $250.00 for the pair from the salvage facility.
Outer shock tower braces guitarman376 Classic Mustangs (Tech) 6 10-11-2015 02:47 AM
New Product - Steeda S550 Mustang Ultra Lite Chassis Jacking Rails (15-16 All) tj@steeda Steeda Autosports 0 09-17-2015 08:57 PM
Steeda’s Vortech S550 Goes 11.2 on Street Tires in Road Race Trim tj@steeda Steeda Autosports 0 09-16-2015 08:53 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
