Eibach springs and anti roll / sway bar kit
Hey guys got a winter project for this winter. I'm going to be lowering my cobra with eibach spring and slapping a anti-roll bar and sway bar. Some people say put new shocks an struts while I'm lowering it. I also have heard about casters to be replaced too. What do u guys think or any other suggestions?
EDIT: I saw where you are from...the roads in Ohio S-U-C-K, DEFINITELY upgrade the other components!!
OK... I think you may be going at this the wrong way If you don't have understeer/oversteer or not sure.... do NOT replace the sway bars. Not to sound like a smart ***, but they don't just automatically make your car handle better or improve stability.
If you have oversteer, you are likely better off going with a lighter rear bar, not a heavier one. Further more, if you are looking at an "anti-roll" bar (I mean this litterally), you will compound oversteer by many times, as this will make rear-axle articulation all but non-existant.
What are the ULTIMATE goals for your car?
Jazzer
Jazzer
Thanks jazzer for the help on that... The goal for my car is to lower it and keep it looking stock. I have somewhat ****ty roads in Ohio and just want something that when I dodge the craters and bump in the beautiful Ohio roads I don't feel like I'm going to loose control.
Well, there is certainly going to be a trade-off between a car that responds well to sudden input changes to the wheel and one that rides nice on rough roads. The "key" is to find a nice balance between the two, so that you don't regret your decision. My advice is the following... take your car out to a LARGE wide-open parking lot and see how it responds under very aggressive driver input. You will find out its tendencies of possible understeer/oversteer and how far you may want to take improvements in how it responds to such input.
Keep in mind, that improving how your Mustang will handle, is in LARGE part the trade-off mentioned above. My car takes an absolute spectacular turn, but the price payed is NVH.
What say you?
Jazzer
What say you?
Jazzer
Last edited by Jazzer The Cat; 10-12-2012 at 03:18 PM. Reason: advice has a "C", silly!
ive always done my stuff in stages.
Springs/Struts for round 1. (and alignment parts too).
Hold off on sway bars till after you have time to live with the springs. Helps figure out what you have before you can determine what you need.
