Suspension Ask all of your general suspension questions here!
Panhard Bar?
Old 03-07-2013, 07:20 PM
silverstang23
silverstang23's Avatar
As Jazzer said most people do it to recenter the suspension on a lowered car. Although some cars you can lower it and get lucky and you don't need it. I have a stiff coilover suspension on my car and I can actually feel a change over the stock PHB. My brother just has springs on his car and you cannot tell any difference over the stock PHB (accept visuals)
silverstang23 is offline
Old 03-07-2013, 07:34 PM
THS_Steed06
THS_Steed06's Avatar
Originally Posted by Jazzer The Cat
You are correct, that most aftermarket PBH's have a mechanical upgrade for harder driving in a few ways. Depending on the ULTIMATE goals for the driver, OEM bushings may be all that is needed. Upgrading to spherical and/or poly is a nice upgrade for one who pushes corners hard, but at the cost of NVH. If there is no desire to run the car hard, got this impression from another question by the same person, then I recommend to stick with and OEM type of bushing to limit the NVH.
Jazzer
Hi guys,
Speaking of poly bushings, anybody know who has a good deal on them right now? I'm about to put my SR performance progressive springs on and wanted to updrade bushings while car is taken apart. AM has only one kit but I was hoping to get specific ones (control arms, PHB, sway bar etc) not every link and all?
Also who's rear sway bar kit would you reccomend for a non-factory equipped steed?
Thanks,
Tom
THS_Steed06 is offline
Old 03-08-2013, 07:34 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I would not recommend replacing either sway bar, unless you are done with ALL other suspension mods and have one of the following.... understeer or oversteer if you have neither or you haven't diagnosed either issue, leave the OEM one.
Jazzer
Jazzer The Cat is offline
Old 03-08-2013, 06:49 PM
THS_Steed06
Hi Jazzer,
I'm not looking to upgrade the front sway bar, but my 2006 didn't come with the rear sway bar stock, so I wanted to add one (other sixers tell me its significantly flattens the car in curves) that's the kit I was referencing.
Mostly looking to firm up the bushings with poly while I'm at it.
Thanks,
Tom
Old 03-31-2013, 03:32 PM
06whitegt
06whitegt's Avatar
If you go the adjustable panhard bar, I'd suggest the type that has the single adjustment on the bar rather than the adjustment at the end fitting. The reason is the mounting brackets at the bar ends make it nearly impossible to tighten the jam nuts after you get the length adjusted.
06whitegt is offline
Old 04-02-2013, 08:35 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
UPR's Panhard bar is stronger than the stock bar, and has Energy Suspension bushings. It is a good strong bar, which will eliminate some of the play caused by the stock bar.
I would not recommend replacing the bushings in the factory control arms. It is very tedious work, and in the end, you'll wish you had just upgraded to stronger arms in the first place.
UPRSharad is offline
Old 06-28-2013, 08:25 AM
Daniel Bente
Daniel Bente's Avatar
A suggestion for your car (as a Convertible, but a good one for all Mustangs) is to get a set of subframe connectors before you get too far into mods for performance. You don't want to twist stress cracks into your unibody on a vert!
Daniel Bente is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Panhard Bar?
