shocks/struts?
shocks/struts?
I have a 2013 V6 Pony Package Convertible.
I had been considering lowering springs for a while and got Hotchkis springs and adjustable PHB.
I am very happy with the stance and the handling but the everyday ride quality is not what I was expecting.
I have talked to many people about the need for shocks/struts when lowering and all have said that with these springs the ride (on OEM shocks/struts) is very similar to stock. Even Hothckis in their description of the springs says they are designed to work with factory shocks/struts.
I believe I have found the problem. ALL of the people I talked to have GT's instead of V6's. The shocks/struts on the v6 cars are softer from the factory than the GT's. And the convertibles get even softer ones.
I believe the springs are too much for the OEM shocks/struts on my car.
I don't have the cash at this point to spring for the STR.T's(which is what I would like to do) but I have found New TakeOff GT shocks/struts for 89.00 for the set.
Would this be an improvement over the OEM equipment? I just need to get it reasonable until I can afford the Koni's or whatever I decide to go with.
Thanks
Thanks
Thanks
Thanks
I definitely would not suggest you getting the GT shocks. They are not the answer to your ride quality.
Thanks for the replies. I have gone back to OEM springs. I am selling the Hotchkis springs and might get something different later but for now I am enjoying the ride.lol. Also the rear of the car dropped lower than the front with Hotchkis springs. IDK if that was because of the vert, or the shocks or whatever.
I have got a couple in mind and was going to ask if anyone has any experience with them.
Eiback Pro-Kit. They have a kit for the vert that includes dampers and springs. I realize it's not a huge drop but that's ok. It is a daily driver after all. I already have the front and rear adjustable sways.
BMR kit. They also have a kit with dampers and springs. Once again not as much drop as the Hotchkis I had but still comparable to the Eibach.
Thanks for the input.
xeroinsanity
07-11-2008 11:35 AM
suzukidragracer
04-07-2006 05:33 AM
