caster camber plates Y/N?
I lowered my 94 cobra 1.5 around. Should I get aftermarket caster cambers? I've seen post of people saying yes and others saying that stock ones worked ok after lowering.
I would say yes. They are not that exspensive and it'll give you that peace of mine. I had brand new tires on my car before I installed the casters and they didn't last long at all.
I recommend CC-plates because the stock ones are poo poo. They have these huge soft rubber bushings, which even when they were new, had way too much deflection. Now that they're almost 20 years old? It's time to go! Upgrade to CC-plates like these from UPR Products, and you'll improve your handling and steering response.
http://www.uprproducts.com/mustang-b...plates-94.html
Thanks... I a actually ordered the upr shark fin c/c plates.., very cheap and looks like install will b a piece of cake.
Question.. u said stock settings is for slow cars..? Well I don't do the alignment myself but how do I explain to the shop I'm taking it too that I want your performance settings..?
Tell them to get the most caster you can get (top of the struts closer to the firewall), camber anywhere between -1° and -2° for an "aggressive street" adjustment, and zero out the toe angle.
Hey guys, its been awhile but had a question. I am ganna be running new wheel setup. 18x9.5 20mm offset up front with a 265 or 275 tire. any idea what kind of alignment I should do? Will -1* to -2* camber apply and zero toe?
