lowering question!!
If you have the same 42mm offset as I'm running, I don't see how there could be any issue at all. I quite literally have around an inch of clearance on the insides of the wheels. The driver's side wheel is about flush with the outer fender, the passenger side is sitting just a bit inside the outer fender.
I'll probably get a panhard bar at some point this summer, along with a UCA, more to bring the pinion angle back into proper alignment.
