Suspension Ask all of your general suspension questions here!
lowering question!!
Old 05-16-2014, 08:54 AM
fidencio74
fidencio74's Avatar
Originally Posted by jRaskell
My axle shifted less than an 1/8th of an inch with Steeda Ultralights. No clearance issues to speak of, even with 18x10 wheels and 285/35 tires.
Is this expected for an 01 as well? I have the same wheel/tires specs in the rear.
fidencio74 is offline
Old 05-16-2014, 09:34 AM
jRaskell
jRaskell's Avatar
If you have the same 42mm offset as I'm running, I don't see how there could be any issue at all. I quite literally have around an inch of clearance on the insides of the wheels. The driver's side wheel is about flush with the outer fender, the passenger side is sitting just a bit inside the outer fender.
I'll probably get a panhard bar at some point this summer, along with a UCA, more to bring the pinion angle back into proper alignment.
jRaskell is offline
Old 05-20-2014, 10:32 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
There's no panhard bar (from the factory) on a 2001.
It's not that there's a big issue about it... it's more the desire to keep the rear end aligned, and not side load the bushings when you're just driving straight down the road. Anyway, I can hook you up on the new suspension bits when you're ready.
UPRSharad is offline
Tivo304
08-28-2023 12:19 PM
04stangman
09-17-2015 01:45 PM
EASTIDEE123
09-14-2015 03:52 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: lowering question!!
