Suspension Ask all of your general suspension questions here!
lowering spring issues
Old 04-20-2014, 09:06 PM
kevin_pianoman
kevin_pianoman's Avatar
Default lowering spring issues
I just lowered my 1998 Mustang GT with American muscle SR Performance springs. The drop is suppose to be 1.5 inches in the front and rear. My problem is the mechanic didn't know which ones were front and which ones were rear. I need to know if the shorter wider ones go in front and the taller skinny ones go in the rear? At the moment the tall skinny ones are in front and I can't drive it much because the drive line is grinding. Especially when hitting a bump. The back is sitting slightly lower than the front. I would think the front would be lower than the rear? Please help.
kevin_pianoman is offline
Old 04-21-2014, 08:10 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
It sounds like you do have the Springs backwards. That is why you're experiencing rubbing issues. You won't have any issues with the SR Springs if installed correctly.
Hope this helps!
-Dan
AMDanBailer is offline
Old 05-19-2014, 09:59 PM
Js88lx
Js88lx's Avatar
LOL... oh oh. Your fronts look thinner and longer than your rears! Its very easy to notice. Im not sure how your mechanic can mess that up! Clearly the fronts are noticeably different than the rears! I think you need a new mechanic! Good luck!
P.s. If you have the longer thinner ones in the front than that's correct but I think you have that backwards! Im thinking you have the shorter thicker ones infront!
Js88lx is offline
Old 05-20-2014, 10:42 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Front coils are the same diameter from top to bottom. Rear coils start out big on top and taper down to a small coil on the bottom. It's hard to imagine someone putting a rear spring (with a small bottom coil) in the front end. It wouldn't seat properly.
UPRSharad is offline
mtgldr
02-03-2024 09:00 PM
PullTab
10-30-2015 08:46 AM
Pyrate Dave
09-10-2015 07:30 PM
robjh22
Suspension
09-08-2015 12:47 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: lowering spring issues
