Suspension Ask all of your general suspension questions here!
Sway Bar
Old 03-03-2015, 08:04 PM
divemaster94
divemaster94's Avatar
Default Sway Bar
My 2015 GT (non PP) already comes with sway bars. Is there any real benefit in installing aftermarket ones?
divemaster94 is offline
Old 03-03-2015, 08:17 PM
BlindGUYnAR
BlindGUYnAR's Avatar
Depends.
Let's start with yes their is value in upgrading to larger, stiffer, adjustable bars, but what handling problem are you having now? Sometimes progressiive springs and/or shocks/struts might be what you need depending on the issue. So depending on what you want to fix there is more or less value.
Explain what you don't like about the current handling and then we can answer if they will help with your specific problem.
BlindGUYnAR is offline
Old 03-03-2015, 08:23 PM
divemaster94
I don't guess there's anything "wrong". This is my first Mustang, and first car with noticeable oompf. I work with a couple of Mustang "nuts" and this is what they suggest. However, if the upgrade is not worth it, I would like to spend the money on something else. Thanks
Old 03-04-2015, 06:47 PM
DK Pony
DK Pony's Avatar
Of course this is my opinion...
I had a 2008 V6 Vert that did not come with a rear anti-sway bar..it helped tremendously when i installed an Eibach Kit.
I sold that car and kept the Eibachs and put them on a 2013 V6 Vert. While yes it "stiffened" the car slightly I can't say it helped the handling at all.
I bought a 2013 GT/CS and only replaced the rear sway bar end links with heavier ones and it helped quite a bit.
So in my opinion the weak link is the end links.
The bars themselves are adequate for most applications but the end links seem to be what is lacking on the factory bars.
DK Pony is offline
Old 03-12-2015, 09:06 AM
Norm Peterson
Norm Peterson's Avatar
There can be, but it kind of depends on how you use your car (or how you might be thinking of using it).
Aftermarket bars are typically stiffer than the OE bars and can be used to dial out understeer and/or improve cornering and turn-in response. You do have to be driving the car quite a bit harder than "average traffic" for this to amount to much.
You will reduce the amount of cornering roll a little, which will tend to improve tire life (especially outside shoulder wear rates). When I say "a little", it's a small enough amount that you probably won't notice much difference in normal driving. The car will take a set a little more rapidly, which you probably would notice.
Norm
Norm Peterson is offline
Old 03-15-2015, 09:59 AM
divemaster94
Thanks for the responses!
Old 03-16-2015, 03:17 PM
DK Pony
DK Pony's Avatar
If you are looking to improve the handling characteristics a good set of Dampers and Springs would help way more than (anti)sway bars.
DK Pony is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
09-16-2015 07:53 PM
Quick Reply: Sway Bar
