2008 GT Lowering Thoughts
Hi All,
I have a 2008 GT that I was considering the possibility of lowering it about an inch, max.
The car only has 21K miles. Is there anything other than the new springs that I need to do?
I have had several opinions thrown my way.
Thank you.
Thank you.
You will need the following:
Springs
Shocks/struts
Adjustable panhard bar
Alignment
Possibly camber bolts
If you only do springs your rear end will be off center ached the socks will wear out really fast.
Good luck.
Springs
Shocks/struts
Alignment
Good luck.
Yes, not as easy as just adding the springs as the rest of the suspension is affected.
At the very least, you will need a panhard bar then followed by the shocks & struts and the CC plates.
Doing the springs & shocks at the same time will save on install labor.
I can provide forum pricing if you email me at tim@steeda.com.
Best Regards,
TJ
Best Regards,
TJ
fcarpio
10-19-2015 04:29 PM
